Old 07-12-2010, 12:07 AM
rickinnocal rickinnocal is offline
Rep: 29 Posts: 35
Keel stepped vs. Compression post
Hi all, I posted this in "Motorsailors", but I think this might be the better forum.
My new project, a 54' Calkins motorsailor, has never had a mast stepped. She has chainplates, and was drawn for a sailing rig, but it was never installed.
The original drawings call for a mast of 50' above deck level, stepped on the keel, so about 57' total. My local yard, where I'm having the boat hauled soon, has a 48' wooden mast from a wrecked boat available. Were I to cut a hole in the deck and keel step this stick, it would be only 40' above deck level - a lot shorter than is called for. However, a couple of people have suggested that, since there is no hole in the deck, I should keep it that way, and mount a steel compression post from the keel to the underside of the deck, bolted through the deck to a mast step.
Some googling has led me to a number of discussions of the alternatives, and I see very little downside to going this way. Do any of the designers on here see a major problem of any sort with it?
Richard
Old 07-12-2010, 12:30 AM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
Richard
I suggest you contact Doug Peterson in San Diego. He worked for Skip Caulkins and may have knowledge about the boat, the construction, and the possibilities.
Doug owns 2 Caulkins 50s.
Old 07-12-2010, 01:35 AM
Rep: 29 Posts: 35
I have talked to Doug via emails, but he doesn't remember anything about the conversion project at all. Until I found design drawings and correspondance from Skip, I think he suspected someone else - maybe the builder himself - had done the conversion drawings.
I didn't know Peterson owned one. He didn't mention it. I already knew he owns 1/3 of Sabrina with Skips son (also Skip) and another owner.
Richard
Old 07-12-2010, 01:56 AM
Richard
Too bad Doug didn't have any good input for you.
Doug and Chris have owned Cathleen together, and also Sabrina. Last I knew they still had both, in some form of partnership or another. I think Ed Reynolds is also involved with one or both boats.
To address your initial question, a deck stepped mast needs to have much higher moments. If the mast you have sourced is not stiff enough you will be seeing a gravity storm at some point.
Old 07-12-2010, 02:21 AM
Rep: 29 Posts: 35
Thanks, I'm going to have a rigger check it out. It's a pretty heavy section for a 48' mast, but I'll see what he says.
Richard
Edit.... This magazine article about the restoration of Cathleen is from May last year. http://articles.dailypilot.com/2009-...san-diego-boat
Old 07-13-2010, 12:38 PM
Rep: 1493 Posts: 7,447
A mast stepped on the keel can have a smaller section because it is pinned at two points. You can always add the extra section with a factory made sleeve and step in on the keel.
Deck vs. keel stepped mast on HR 34 bluski Sailboats 1 11-16-2008 01:45 PM
Mast step, compression Post, chain plates skygusty Boat Design 2 08-13-2008 07:43 PM
water in bilge - fact of life on keel stepped mast? mattplowman Sailboats 11 04-02-2008 02:44 PM
?? about compression pipe in a mast!!! MarioCoccon Sailboats 3 04-26-2006 07:42 AM
