| Keel modification / CFD analysis hi to all, that's ok that lead keel dosesn't look so good, Now we want a bigger RM , for IMS rating and stability, where we are it' s quite expensive building a new one. we have the possibility of making some modification/optimization to the existing one, also using CFD at university. Today i mesured and made the 3d model we are going to test I woluld like to post in coming week the development about this Has someone some similar experiences or may suggest the best way to proceed? |
| Casting lead isn't impossible task to do.. Anyway I would.. if I had enough of it.. |
| Thanks you, teddy we are just evaluating some alternatives at the same weight here he models . in teh middle th exsisting one on the left a possible modification and on the right an ipothesis for a new one ... any opinion ? thanks |
| Keel modification. This is an interesting shape. Would you care to explain the thinking that leads to it? Ivor Bittle |
| Hi ivor thank you ; the existing one was modified with 170 kg in the bulb to give somewath more stability ... however the boat stll has an hig cg and we are evaluating some alternatives for better stability with less drag .... any suggestion? |
| Keel modification. I could not believe my eyes when I saw this keel. Try my web site www.ivorbittle.co.uk section 1 section 6 on the keel and bulb to see where I think you should be. You will see why I am not surprised to hear of your stability problems. There is no reason to use cfd when we have ironclad data to work with and getting the shape right is more important than anything else. Come back on this if you think that I can help. Ivor Bittle |
| Lead Keel Modification | Dick Flower | Boat Design | 25 | 07-21-2008 11:56 PM |
| Amateur Laser Design modification in keel and sail | tatria | Boat Design | 7 | 06-27-2008 05:45 PM |
| Mission analysis | rkpshenoy | Multihulls | 3 | 06-11-2007 05:45 AM |
| Analysis software | concrete canoe | Boat Design | 2 | 02-01-2005 08:50 PM |
| seakeeping analysis | nechita67 | Services & Employment | 1 | 07-13-2004 06:53 AM |
