| Keel design at prop She's a 57' George Beuhler designed cruiser and I am nearing the end of building the keel. My engine is a DD4-71 and I have a 2" shaft to a 28-20 3-bladed RH prop. The keel is 11" thick. My question is what is the best way of carving that big thick keel in the area around the cutless bearing housing so as to maximize flow over the prop and minimize the kick of the prop as well. I assume I will want to carve what, viewed from the stern, would look like an "S" shape, with the shaft coming out in the middle of the "S" but my question is, which way will the prop kick the boat? And which way should the "S" face? Should it look like a standard "S" viewing her from the stern, or a reversed "S", and why? If this is not a clear question please view my little attached drawing. View my progress at this album page: http://picasaweb.google.com/GreyFox1931/GregSBoatyard# |
| Again, duplicate post, see the wooden boat section . . . |
| Props are designed to work in a uniform steady flow, and creating a non-symetrical flow can bring some surprises, especially considering cavitation. The most important is to minimize the wake of the hull on the neighborhood of the prop (the part affected by the boundary layer created by the hull). The best thing to do is to smooth both sides of the keel as much as you can, and avoid the sharp squared trailing edge of the keel |
| New Keel design..... | fhrussell | Boat Design | 1 | 03-10-2007 09:04 AM |
| Keel Design | Lyle Creffield | Open Discussion: All Things Boats & Boating | 2 | 01-05-2007 03:59 PM |
| duo-prop shaft design | fisherman | Propulsion | 8 | 07-09-2004 05:43 PM |
| duo-prop shaft design | fisherman | Services & Employment | 0 | 05-29-2004 07:39 PM |
| keel design | max | Boat Design | 3 | 10-18-2003 04:33 PM |
