Old 03-24-2005, 03:44 PM
ivansalasj ivansalasj is offline
Rep: 10 Posts: 63
KB from lines plan
Hi,
Just a quick question.
What is the simplest way to calculate the KB from a lines plan, shall i first calculate say the sectional area of say 15 sections and then ???
Thanks for your help.
Ivan
Old 03-24-2005, 06:01 PM
DaveB DaveB is offline
Rep: 11 Posts: 128
Originally Posted by ivansalasj
Hi,
Ivan
I don't know of any real shortcuts... It's pretty much the same as finding the centre of gravity of a homogenous solid... something that should be described in most basic math, physics, or engineering texts (solids). If you've got it in cad you can often get the areas of regions from the package, and if on paper a planimeter is a common tool... either that or graph paper... From there you've gotta calculate the moments of areas from a reference pt and then divide that by the total area to get the location of the CoB from the reference point. Usually has to be done in all three dimensions, but most boats have symmetry so TCB is often zero...
Good luck with it...
Cheers,
Dave
Old 03-25-2005, 03:18 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 484
You can use Morrish's formula (approximation):
KB = 1/3*(2,5*Tc-V/WPA)
Tc = Draft of canoe body
WPA = Water plane area
V = Dispacement volume
Not sure if this is the original, anyway it gives reasonable numbes.
Old 03-25-2005, 07:34 AM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 312
Do the standard 11 or 21 station layout, compute sectional areas and use simpsons rule.
Lines plan from Rhino AndyRed3D Software 14 08-04-2004 12:05 PM
Lines plan to 3D hull form in shipconstructor. Emil_h Software 5 07-25-2004 12:13 PM
From lines plan to 3d hull form ivansalasj Software 13 07-23-2004 11:53 AM
lines plan development fede Boat Design 4 11-23-2003 08:30 PM
lines plan for cal 2-29 trimhorn Boat Design 0 06-20-2002 03:45 PM
