Old 12-30-2007, 10:15 AM
pkoken's Avatar
pkoken pkoken is offline
S/V Samadhi V
Rep: 43 Posts: 98
Kayak an efficient displacement stern shape?
I have been pondering the concept of a long, narrow displacement motoryacht. Steve Dashew's Wind Horse started my thinking along this path...
But why use a conventional flat transom at strictly displacement speeds? I can see that the additional space would not be of much use in the extreme stern (the same as in the bow). There also must be some efficiency lost because of skin friction...
Sailboats don't use this type of transom anymore, and they are usually out for maximum efficiency.
Why don't we see kayaks with "transom" sterns?
Regards
Phil
S/V Samadhi V
Old 12-30-2007, 10:30 AM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
I think you answered part of your question. There is no need for space at the aft end of a kayak.
Another reason is that a kayak does not operate like boats meant to mostly run in a straight line. It needs to be maneuverable and this implies more symmetrical ends and rocker in the hull.
A bigger reason occurs when you are running rapids. In this case the water is more often going faster than the boat. In this case, it's easy to see that a pointy bow shape is needed in the stern. A transom stern would make the kayak more liable to loose steering control and broach. Happens too often even with a pointy stern.
Tom Lathrop
Old 12-30-2007, 04:51 PM
Previous Member
Rep: 0 Posts: 0
Regards
Phil
S/V Samadhi V
Phil
There have been a few discussions around on Atkin hulls. These are a canoe under water but have a flat transom.
http://boatdesign.net/forums/showthr...ighlight=atkin
There are other examples as well such as this cat that has canoe hulls:
http://www.boatdesign.net/gallery/sh...0/ppuser/22903
Modern sailing boats have power to burn so are designed to plane easily hence the wide flat stern.
If you want an efficient hull for displacement speed then the canoe stern is best but it does not mean you have to be constrained to the canoe above the water. I did the attached hull for a speed of 6kts. It only requires 1kW to do 6kts and it displaces 4.5 tonne.
Rick W.
Kayak an efficient displacement stern shape?-opt_6kt_linesplan.jpg  Kayak an efficient displacement stern shape?-opt_6kt.jpg
Old 12-31-2007, 10:31 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Rick, it occurs to me that for folks who are not committed to solar power, this boat might be driven via an electric motor powered by a small generator. The generator can be used for other power needs on the boat at mooring. I'm intrigued by these new generators that weigh less than traditional generators, produce clean sine wave AC and are more fuel efficient due to their inverter designs:
http://www.a-chainsaw.com/yamaha-inv...0is-p-239.html
http://boliygenerator.com/index.html
Kenneth Grome
Old 12-31-2007, 10:56 AM
pkoken's Avatar
S/V Samadhi V
Rep: 43 Posts: 98
I am curious about the aft deck extensions (where they overhang the stern on the sides) what happens in a seaway when these are exposed to waves? There looks like there is a lot of additional buoyancy in the stern when it is down in a wave- will this cause the bow to submerge?
Regards, Phil
S/V Samadhi V
http://www.samadhiv.org/
Cruising Hawaii
Old 01-02-2008, 05:20 AM
Munter Munter is offline
Amateur
Rep: 100 Posts: 222
Sailboats use beamier stern sections because they help generate righting moment as well as providing interior space (though that isn't exactly a concern on an open 60 sailed by one fellow...)
Cole 43 Rumrunner II - An Australian classic
My home efficiency/renovation blog
Old 01-03-2008, 04:05 PM
Petros Petros is offline
Rep: 717 Posts: 767
Sea kayaks operate in pure displacement mode with very low power output at relatively small Rynolds numbers. They optimize the least power demand over long distances at low speed. The lower speeds they operate at (3-5 knots) means the skin friction of the stern is less significant than the drag of a flat transom (which may not be true at higher speeds).
Also when paddling a sea kayak in a following sea a transom raises the tendency to broach and lose control. Without a deep keel and wide beam a broach unusually leads to a capsize. the sharp stern allows the swells and even waves to pass the hull with less disturbance.
Since sea kayaks typically not do use rudders (yes I know many vender's are happy to take your money for them, but historically native watercraft do not use rudders-they are "white man" inventions), you need a skag as far aft as possible to improve directional stability, turning is accomplished by tilting the hull on edge and differential paddling. So a fine stern tapering to a point helps directional stability without a deep skag or keel.
If you are operating in the same speed range as a sea kayak likely a "canoe" stern would be the best shape. All of the design effort put into hull design for both power and sail boats yields the transom stern designs than likely that also has the best drag and handling properties for that size and speed. You will likely not discover something new by putting a kayak stern on a larger powered hull.
Old 01-04-2008, 05:25 AM
Rep: 700 Posts: 3,208
"If you are operating in the same speed range as a sea kayak likely a "canoe" stern would be the best shape."
To me that would be a SL ratio of 1.1 or under.
FF
Old 01-04-2008, 06:24 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
http://www.hallman.org/bolger/Illinois/
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 01-13-2008, 04:11 PM
aka Terry Haines
Rep: 1682 Posts: 2,818
A few canoes have been made with a transom to accommodate a small outboard motor but they are typically for flat water conditions. Saw a nice one the other day with a wineglass stern above the water line to limit drag.
Underwater stern scoop on large displacement powerboats? BIGBOATBUILDER Powerboats 12 12-11-2007 06:28 AM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 08:36 PM
Efficient Displacement Hulls Karsten Powerboats 19 06-07-2006 09:25 AM
Stern shapes on displacement motor-cruisers marshmat Powerboats 21 10-12-2005 07:11 AM
Transom vs. V Shape for Catamaran Stern Hull Free Pirate Boat Design 15 03-17-2005 07:16 AM
