| Kayak Boat Hull Material I am in the process of building a strip built kayak, or in this case a hybrid kayak using strip built technique for the deck and plywood hull.. What material would anyone recommend for the hull? 1/4" Luan or something else. I will be epoxying and fiberglassing the entire boat so would the hull material make a big difference? Also any suggestions about the best way to cut it to fit the forms or use the stitch and glue method? Just looking for some ideas... thanks |
__________________ Kenneth Grome |
| Kayak Boat Hull Material Thanks for the answering. Would you recommend door skin luan or something a little thicker.. Obviously i need something flexible enough to bend around the forms? Also being so thin, would you recommend screwing it to the forms or glue? |
| i'd use both screws and glue,,and door skin would be fine to use,,,as long as your using it for a "form" and not for "strength. quick question,,,did you come here from "yahoo answers"? nice meeting ya newayz hehe ![]()
__________________ hehe ,,,,,Jim------> |
| I will be using it for forms and hoping the strength will come from the epoxy and fiberglassing. Once finished i doubt i would be using the boat in rough water anyway where alot of rocks etc. Mostly the sound and local lakes. I am wanting to use the door skin etc for the hull and instead of strip building the entire boat... No.. i didnt come from Yahoo answers.. I was looking around on the internet yesterday for Q&A forums on boat building and happened to find this one... haha nice meeting you also Jim |
| It may be helpful check out my blog which goes through a step by step strip plank canadian canoe - au.360.yahoo.com/greenwoodenfish I used 5mm strip planks, which are probably as light as you would want to go, otherwise you would sand through them while finishing and fairing, and the skin wouldnt be thick enough to provide sufficient rigidity with the fibreglass on both sides. Personally, unless you are really keen on the wood finish and style, I would go for a plywood canoe/kyak to avoid the work and fuss inherent in this method. |
| wellz cool,,i was asking cause i sent a dude here from there asking the same question,,hehe ![]() and i guess you'll learn,,but when ya ask 1 question here,,,you get 38.7 questions asked to you before any answers hehe ![]() so on with it,,,,,,have ya ever done any of this work before,,(not as job like,,just ANY experience) glassing,,using epoxy< im not a epoxy dude,,but they'll be here soonz hehe ![]() and be patient,,some times it takes a few days for the "old kodgers" get their glasses clean,,but they'll be here ,, dont say i didnt warn you hehe ![]()
| thanks rwatson: I will check out your blog on it... the1much... I hear ya.. haha...i have done some epoxying and glassing before..I used to live in Florida and did repair work on boats..just in Florida the boats were on a much bigger scale.. :-) |
| Layup of kayak material question | Thin water | Fiberglass and Composite Boat Building | 4 | 08-01-2007 12:30 AM |
| HDPE as a boat hull material | JonathanCole | Boat Design | 14 | 06-14-2007 03:15 AM |
| Kayak hull joining question | Thin water | Fiberglass and Composite Boat Building | 12 | 07-06-2006 12:43 PM |
| Best way to join deck to hull of kayak? | Grantman | Fiberglass and Composite Boat Building | 6 | 11-28-2005 09:41 AM |
| boat material / furniture material | bogeyinthekeys | Materials | 7 | 09-10-2005 09:29 AM |
