| Kavalier 800 I have downloaded and gone over the plans for the Kavalier 800 and have some questions. What is the drop keel constructed of ? I presume that it is a lead casting (to provide ballast) but there is no note of this (that I have found). What is the drop keel housing constructed of? I must say that these FREE plans are very professional!! Thanks in advance for your assistance Matthew |
| Fixed keel is supposed to be assembled as 'sandwich' of vertical steel paltes of about 5 mm thickness. Or You can use iron or lead casting also. Drop keel is actually centerboard that can be made of steel plates or plywood. No need to make it heavy. |
| Thanks Thanks for the quick reply Alik. Matthew |
| Hi, Albert! It is nice to meet you here. ![]() |
| Hi Alik This is my first ever post. sorry for replying to such an old article but I am looking at building the t800 also. My query on the keel is- how do you pull it back up as it does not have a casing that extends into the cabin. Do you have an arrangement where it is pulled up by a steel cable over the stern somehow? |
| About the keel Quote:
I'm rather interested in the fixed keel option and would be keen to get the drawings. James at yahoo dot com Regards, James. |
| Free design for amateur boatbuilders | Alik | Boat Design | 275 | 09-01-2011 11:23 PM |
| omc problems | double00 | Propulsion | 9 | 08-07-2006 09:27 AM |
| OMC I/O 800 Swap out whats possible? | firestorm | Propulsion | 1 | 05-12-2006 12:52 AM |
| Kavalier 800 | center | Boat Design | 4 | 07-14-2005 10:32 AM |
