View Poll Results: should my freind use junk ship sails or not?
yes he should. 6 54.55%
no he should not. 5 45.45%
Voters: 11. You may not vote on this poll
Old 03-01-2005, 05:48 PM
boby boy boby boy is offline
owner of cla boat design
Rep: 10 Posts: 32
junk ship.
I have a friend who is starting a project and is thinking of doing it with junk ship sails. Does any one no the benefits or problems with these? Should he do it or not?
Old 03-01-2005, 06:44 PM
Rep: 1493 Posts: 7,447
Is it new or a retrofit?
Old 03-02-2005, 04:44 AM
Rep: 756 Posts: 3,328
They work great , ON a Junk
That means traveling with the Monsoon , no windward work .
FAST FRED
Old 03-02-2005, 05:51 PM
Rep: 10 Posts: 32
it's new.
signed boby boy
make life fun :)
Old 03-02-2005, 08:49 PM
Does the design have a junk rig? If not it would need to be completely redesigned structurally. The masts are located farther forward. I think it is a type of rig with some advantages. Among them the ease of handling.
Old 03-03-2005, 06:43 AM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Ease of handling or junky performance?
The advantages are:
Ease of handling (esp. reefing),
relatively low cost for hardware (can get by with no winches except, perhaps the halyard),
repairable with simple tools,
can sustain considerable damage (rips and holes) and still be useable, and, in my opinion,
looks cool (sticks that finger way up against conformity).
The disadvantages are:
higher center of gravity than a gaff rig (all them battens),
poor performance in windward work (can actually point higher but foots way slower),
lots of little lines, fair leeds, and pulleys (to control all them battens),
needs an unstayed mast, and
sicks that finger way up against conformity (not especially good for resale value)
My advice:
If for cruising and especially cruising far off the beaten path where ease of handling and reliability are more important than performance, use it.
If for even occasional racing, forget it.
Bob
Old 03-03-2005, 02:27 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Camber
Check a desent camber (over 6%) in your junk sail to have some windward ability. Anyway this one works.
Old 12-15-2009, 03:08 PM
dskira dskira is offline
Rep: 1305 Posts: 1,372
Nice boat
Old 12-17-2009, 05:25 AM
Typhoon Typhoon is offline
Rep: 150 Posts: 125
Freedom rig is just as easy to handle, much lower CG and goes to windward. Sails MUCH cheaper too.
Regards, Andrew.
Old 12-17-2009, 06:23 AM
"Sails MUCH cheaper too."
Cheaper than old rice sacks?
FF
Old 12-18-2009, 06:43 AM
Rep: 150 Posts: 125
FF
Sorry, thought we were talking about realistic materials here. I haven't seen a modern junk rig with rice sack sails.
Regards, Andrew.
Old 12-18-2009, 12:45 PM
terhohalme's Avatar
Rep: 478 Posts: 485
The one above is just cheap white PE tarpaulin.
Only shared knowledge can grow.
Old 12-18-2009, 01:01 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Tyvek is also cheap and strong..
Old 12-18-2009, 02:13 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
Why does the Freedoms rig have a lower CG? because they have carbon masts,thats why,its ridiculous to compare carbon masts to tree trunks,if one were to put carbon masts and battens on a junk rig you would also lower its CG but take away its economy and reliability.Also,the sails would have to be much cheaper for the junk even in dacron,you can sew them yourself as there is no shaping required,they are just a series of flat panels between the battens so no sailmaker with a computer program required,just a competent person with a heavy duty sewing machine.
Steve.
College for Naval Architecture Archive Education 15 04-07-2008 12:42 PM
Faster upwind tacking by taking turns towing? h.t.hall Sailboats 17 06-24-2005 01:49 AM
Better Freedom Ship Dook Boat Design 5 03-13-2005 06:00 PM
I need a Lead Naval Architect or assigned Project Enginner ESG Services & Employment 12 11-06-2004 09:29 AM
Chinese Steel Tall Ship Builders? Adam Baker Metal Boat Building 4 07-03-2004 10:15 AM
