Originally Posted by Easy Rider Thed,
Your last dimensional specs seem fine to me if you can eliminate the 3rd person. Not much has been said about V v/s flat. Go flat. You mention rivers so it looks like shallow draft and beach ability should be important. The outboard will need to be mounted lower w the V bottom. An inverted V may even work well for you but I'd just go flat.
Take a look at one of Atkins designs .. Little Peter w 3'10" beam and Dancer w 3'9" beam. LP is a punt w better capacity and stability however LP has lots of rocker so 5 knots tops. Dancer is typical small row boat/skiff w pointy and squareish ends .. faster and (to most) better looking. Dancer is rated for 3 people and LP should do that even better.
Easy Rider |
in all honesty, 3 people was optimistic and was used mainly to give a large buffer for 1+ large dog or 2 people. Thanks for the suggestions, i'll check them out. I was considering changing to a modified V and try to get the best of both worlds but am now quite intrigued by inverted V and will have to research more. The project builder in me wants to build the hardest type of hull shape i can but I'll go with whatever can give me the best performance overall.
