| Jon Boat: Mounting a Trolling Motor? I have a Jon Boat without a front deck. The front seat is recessed in the boat about 4-5 inches. What is the best way to install a foot control trolling motor without adding a deck all the way across the front? Thanks. |
My troll moror is the "pivit" mount type. It is held onto a flate aluminium plate that is set to the port edge of the bow. 4 # 10 ss screws on the port edge & 3 on the bow edge. The plate is 1/4" so is stiff enough that no leg was necessary down to the seat. Pull a pin & the whole troll motor comes off.
| Thanks Ted! Where did you get that plate? |
I made it. Around here, aluminium boats are being built at several places. AND, I have 3. Finding a chunk of 1/4" or 3/16" plate takes but a little effort. A rectangle of 6" W X 24" L should do. Have some idea of the pivot mount geomotry first. A grinder, then belt sander will round everything off smooth. ESPECIALLY the 1 corner that sticks over into the boat. Cut that corner at a 45, then round it good.
| Bayliner 175 bow trolling motor, how? | boatmen | Powerboats | 3 | 01-24-2007 08:52 AM |
| Trolling motor for aux power | LP | Sailboats | 23 | 04-27-2006 12:10 PM |
| Cavitation and Mounting Motor | Colin Hartley | Open Discussion: All Things Boats & Boating | 2 | 12-15-2004 01:12 AM |
| Mounting height of outboard motor | finfinder951 | Powerboats | 2 | 05-18-2004 03:31 PM |
| Outboard Motor Mounting Height | Guest | Powerboats | 4 | 10-31-2003 04:55 PM |
