Old 04-23-2007, 11:11 AM
Sven190 Sven190 is offline
Rep: 10 Posts: 2
Jet sled restoration project
I have aquired an 18 foot jet fiberglass jet sled. I was given the boat as a project. The boat was a prototype, built by a highschool shop teacher in 1985. The stringers he used were fir 2X4's and the deck was plywood glassed over. The stringers were NOT left unglassed on the top and the plywood deck unglassed on the bottom. Webs that were put in are totally rotted out. The hull itself seems sound but the deck is rotten and the plywood delaminated. I cut all the deck outand am now in need of advice as to how to replace the stringers. A friend who worked for uniflite for 9 years in the 60's and early 70's had the idea to make the new deck out of foam and glass it on both sides. We are unsure if we can remove the stringers and do this and maintain the structural strength of the boat. Or do I put the stringer back in glass them correctly and use foam around them? Oh and weight is an issue, the boat has a 90 hp outboard jet, and as near as i can figure was about 4000 lbs in it waterlogged state when i aquired it. I am trying to keep as much weight out as possible. So far have removed about 600 lbs of water and wet wood.
Old 04-24-2007, 12:18 AM
twisterme twisterme is offline
Rep: 10 Posts: 7
Some pics would be good to see what you have to work with. IMHO, go with a replacement ply deck. An AC grade will be fine. Fill voids with epoxy resin paste and coat both sides with epoxy resin. FG the exterior with epoxy resin and 2 layers of 6oz cloth. Stringers should be replaced with 2x6. Grade 1 Doug Fir will be fine, but make sure you epoxy resin coat all surfaces first and then bed with epoxy paste fillets. I would bore some holes to see how much of the wood is waterlogged, especially the transom, then make decisions on where to go from there.
Old 04-24-2007, 07:59 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Use the hull as a base and cold mould a better boat with BS 1088 Okume and epoxy resin. Refit the other components and you'll have a lighter and much stronger craft than a waterlogged frozen snot boat with suspect safety and the smell of failure.
http://ivb-boats.netfirms.com/HistoryOf-SeaSled.html
Pericles
1920's sailboat restoration project BMH Wooden Boat Building and Restoration 7 02-07-2007 04:57 AM
Searching for restoration project sronicker Sailboats 4 06-28-2006 05:31 PM
Design....15'-17' alum Jet Sled w/PWC jetpump glassiches Boat Design 8 05-31-2005 09:27 PM
New Restoration Project Questions IHTFP Fiberglass and Composite Boat Building 4 05-18-2005 12:49 AM
