Old 03-30-2007, 10:04 PM
Capt Sport Capt Sport is offline
Rep: 12 Posts: 8
Jackshaft pros and cons
I'm interested in jackshaft power for my next boat. And, was wondering if some of the more experienced designers on here could tell me the pros and cons of powering this way.
It seems to me that a boat with jackshafted power would be much better balanced, ride better and be more efficient. But I'm sure I'm missing something, or more boats would be built this way. It can't just be that outboard boats are cheaper to build.
Just to give a little background on the boat I have in my head:
Aluminum
Center console or center pilot house (full walk around)
24-28' lenght overall
8'6"-9' beam (dependant on length)
diesel power
What I'm looking for is a rough water boat, with extended range (80-100 gallon of fuel). That is as cheap to run as possible. Think of it as some of the Pacific north west boat designs without the great big full width house and cabin. I'm not looking for the fastest boat on the water either, cruse at 20 knots top out at about 30 knots.
Thanks in advance for you help and input,
jr
Old 03-31-2007, 04:24 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
JackShaft to ...
Capt, A jackshaft (typically with universal or CV joints) can connect the engine to a conventional propshaft/shaftlog with thrust bearing, OR a Vee Drive, OR an Outdrive, OR a Jet, OR a Surface Drive. What are you thinking about?
Regards, Terry King ...On the Red Sea at KAUST
Old 03-31-2007, 05:40 AM
Rep: 700 Posts: 3,207
The best advantages of the drive is,
the shaft is quite short from the thrust bearing out , so replacement is cheaper.
And the engine can be on far softer mounts for a smoother quieter ride.
And of course an engine change is easy as no difficult shaft alignment is needed .
FF
Epoxy Vinyl Ester? Pros and Cons? allan white Materials 2 03-19-2007 03:07 PM
Stepped hulls pros and cons AdrianRO Powerboats 8 11-24-2006 07:43 AM
Pros and Cons of an I/O system shadowrack Powerboats 5 02-17-2006 09:11 PM
Inflatables, pros & cons? Splint Open Discussion: All Things Boats & Boating 20 05-16-2005 02:54 PM
Pros and cons of Redwood for boat construction? Materials 6 03-23-2003 02:09 AM
