Old 04-19-2009, 12:23 PM
k_skit k_skit is offline
Rep: 10 Posts: 8
ISO 12215-5 Effective Plating for Plywood
Dood day for everybody!
Could somebody make it clear for me what is the meaning of the term "effective plating" in the ISO 12215-5? I am particulary interested in plywood on wood construction.
Chapters 11.6 and G.5 state "effective plating" for plywood on wooden stiffeners as 15 times plywood thickness plus the stiffener width.
Does this mean the distance between the stiffeners should be less than the effective plating?
In other words:
The example at G.5.5.1 says that the effective plating for 50x50mm stringer on the 15mm plating is 15*15+50= 275mm
Does it mean that stringers are to be placed not wider than 275mm?
Hope for some answers...
Old 04-20-2009, 01:45 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
It can be said that way too when the stiffeners have same dimensions.
Old 04-20-2009, 04:54 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 484
When calculating the section modulus of the stiffener you can take a "virtual strip" of the plating to be a part of the second moment area of the stiffener. This virtual strip is "effective plating". This is only possible when the stiffener is glued onto the plate.
In your example, if the stiffener spacing is 250 mm, you couldn't calculate the effective plating wider than 250 mm. If your spacing is 350 mm, you could use 275 mm wide strip as an effective plating.
Only shared knowledge can grow.
Old 04-21-2009, 01:25 AM
Rep: 10 Posts: 8
Dear gentlemen! Thank you very much!
ISO 12215-5 and Principles of Yacht Design CanuckGuy Class Societies 18 12-24-2009 12:25 AM
Iso 12215-7 sholt85 Class Societies 1 03-24-2009 02:31 PM
stiffener calculation for ISO 12215-5 wendyyacht Boat Design 0 05-15-2008 02:54 PM
Question about ISO 12215-5 lyqqmxm Class Societies 0 02-29-2008 02:00 AM
effective plating eduard Class Societies 6 11-13-2007 04:42 AM
