Old 05-27-2004, 08:04 AM
RThompson
IRC and Bowsprits, or not?
Hi,
I'm interested in peoples coments and arguments regarding the impacts on IRC rating when one is comparing the rig configuration of:
-spinnaker pole only
-spinnaker pole and bow sprit (or articulating bowsprit)
-articulating bowsprit only
given that the boat in question was not built with a bowsprit.
Not currently rated under IRC, in fact not designed to a rule.
7 years old 40' light displ., cold molded WRC, beamy and stiff. Racing mostly offshore.
Thanks,
Rob
Old 01-31-2005, 08:26 AM
gybeset gybeset is offline
Rep: 5 Posts: 36
IRC spin pole tradoffs
IRC 2005 rules updates (go to rorcrating.com site) clears it up a bit,
I still wonder however if you have a canting sprit X long, does it get the same factor as a normal articulating pole
how much factor do you 'wear' for carrying your normal pole as well
is there an ( factor) advantage for getting rid of normal spinpole and having a a) centreline sprit seems so
b) is there an advantage of ridding boat of normal pole if you have a articulating (canting) Sprit
C) in the case of a or b is it worth pursuing ??
just to muddy things further, how about factor diff of a shorter articulating Sprit versus a longer centreline (noncanting) Sprit , i,ve gotten rid of the normal kite pole now !!!
