Old 10-03-2010, 01:45 AM
portacruise portacruise is offline
Rep: 154 Posts: 626
Originally Posted by Squidly-Diddly View Post
I figure it would have a few advantages(in certain situations).
1)if you are able to launch it in a storm, once you get up in the air it should be 'smooth sailing' as you will have ZeroAirspeed. I believe most "bumpy air" results from the airliner traveling through zones at 500MPH.
2)A balloon with a few radar reflecting strips should be easier for Search and Rescue to find. I believe airliner's radar would pick it up once you get to about 10,000ft.
3)You would have the OPTION of getting blow in the Right Direction, or putting down on the surface and deploying a sea anchor(or staying 100' up and deploying sea anchor.
4)Sharks don't fly.
5)the big bottle of Helium could double as Fire Suppression.
What's wrong with an inflatable version of the emergency escape pods that oil rig workers use? Once the strong winds pass, you could use a balloon to get a long antenna up to make contact with rescue and make the pod easier to see.
Porta
Old 10-03-2010, 11:50 AM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
In the 60's I was stationed on the CG Cutter "Matagorda" out of Honolulu. We stood OS Victor patrols, 30 days on station in the N Pacific in the middle of winter. A daily ritual was the release of helium weather balloons to track winds aloft by radar. Now this was on a 311' cutter, and we had an enclosed "balloon shack" with a roller door on the 02 deck to inflate these things. You inflated the 8' diameter balloon, the ship turned into the wind, the roller door was opened and out you go with the balloon and release it. If all goes well, nothing goes wrong. As Yogi Berra said, "In theory there's no difference between theory and practice, in practice there always is." Somehow those balloons could get into the most incredible tangled messes even when we did things right. If this is how it is with some control, in reasonable weather, on a 2000 ton ship, how the heck do you deal with a much larger balloon in a terminal survival situation when absolutely everything has gone bonkers?
Old 10-04-2010, 06:10 PM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Bataan, very good point. I was an air traffic controller in the Army and released balloons to take weather observations. One would not do at all.
The best way is to get a box of smaller balloons and tie them together and tie them off to a lawn chair. Remember to strap a sharp tool to the chair so that it is not lost so that you can pop the balloons as needed to maintain your flight level at differing tempatures and ultimately descind!
I'd go for the stronger boat first, then a life raft, then maybe that submarine!
Old 10-04-2010, 06:51 PM
ddrdan ddrdan is offline
Rep: 37 Posts: 66
A water ball and a scuba tank??
http://www.uswaterball.com/
Old 10-04-2010, 07:48 PM
srimes srimes is online now
Rep: 186 Posts: 226
While we're at it, why not just have an inflatable helium chamber big enough to lift the whole boat? A hybrid boat/airship. With solar panels and electric powered propellers/turbine wind generators. Then when the storm is coming you can fly above the clouds into the clear sunshine to keep the naked hippies warm in the organic garden.
Old 10-05-2010, 04:07 AM
Rep: 501 Posts: 1,767
Actually may be idea has some merit. But you need something really heavy to acts as a keel. Saw on TV one time what look like a personal raft, but your feet extend below to act as keel. So something like a giant sperm, were your legs go into the tail and you float around. might actually be better than raft. If it could be made water tight and insulated....
Old 10-05-2010, 09:28 AM
Rep: 1758 Posts: 1,561
Been there, done that...
Old 10-05-2010, 12:26 PM
Milan Milan is offline
Rep: 279 Posts: 320
Originally Posted by MikeJohns View Post
… put the resources into making your boat as seaworthy and as durable as possible…
I’m with Mike on this one.
If you are worried about sinking, invest money in the boat structure and maybe build in some watertight compartments and flotation. Boat is MUCH safer and more comfortable place to be in the storm, even when damaged and partly flooded, then life raft and similar.
Fortunately, I don’t have a real life experience of escaping sinking yacht, but I got a merchant marine survival training, life-raft handling and such.
Even simulated situations are hard enough …
Viking Lifeboat JippyJoe Fiberglass and Composite Boat Building 6 11-30-2010 06:18 AM
USA-Technical Details-Helium used Doug Lord Multihulls 107 05-15-2010 12:47 PM
HELIUM Chris Ostlind Open Discussion: All Things Boats & Boating 5 04-07-2010 05:00 AM
lifeboat help zeroname Software 2 12-01-2008 06:29 AM
Foil construction concept trial balloon bistros Sailboats 20 04-26-2007 03:34 PM
