| "The hook Atkins used was to keep the bow down when the hull was pushed past 1.4 S/L ratio." Not so sure,about the "hook", The reports I read of a boat that was plans built , and then swopped to a much larger engine was the boat BOW STEERED . Atkin simply added a set of chines forward to lift the bow as much as the stern at the much higher speeds. A true plain hull is probably best over SL-3 but below that the ability to motor fast WITH efficiency is of interest. Would be interesting to see what Atkin would do today with very light weight engines and hull materials cheap enough for the home builder. FF |
The only difference in my design is that there is no back panel on the keel to close it off. I left it open to allow water to flow through the keel so it does not block water flow to the prop at low speed. When the boat is planing it shouldn't make any difference that it is open because water will peel away from the transom bottom there rather than flood the box keel. Quote:
I don't know how much power Seaknife hulls require to get up on plane. Maybe they require "unreasonable" amounts of power, but there is no question that these hulls plane exceptionally well at high speeds: ![]() Quote:
I added the box keel -- in the shape of a Seaknife hull -- specifically to allow the boat to plane on a much smaller surface, just like a Seaknife hull planes on its narrow triangular bottom. Planing on a smaller surface smooths the ride and prevents (or substantially reduces) violent pounding. Creating a boat that planes smoothly in less than ideal conditions is one of my primary design goals here. The hull without the box keel will plane but it won't plane smoothly unless the water is very smooth and flat. I want this boat to ride nice when the water is neither smooth nor flat. Quote:
I acknowledge the fact that there may be better ways to deal with the low speed flow of water to the prop. There may also be ways to reduce surface drag from the free flooding box keel while retaining its desirable characteristics. This is why I posted here ... so others can see the concept and make suggestions to improve the design before I build it. Thanks for your comments PAR, they are very much appreciated!
__________________ Kenneth Grome |
I have considered changing the shape of the free flooding box keel so that its bottom is angled up from back to front (similar to the angle of the bottom of the box keel in the second image). This will provide a lifting surface to help the boat get on plane more easily. One side effect (and a possible advantage) is that it positions the box keel in its natural planing attitude which would reduce the upward pitch of the boat as it transitions from displacement to planing mode. Quote:
Please look at the attached Seaknife images (not just the thumbnails but the full sized images) because some of them have captions that refer to this stabilizing effect. There is lots more written about this effect online, some of it in the patent applications by Peter Payne, but I don't have the references handy. If you're interested Google can probably find more for you rather quickly. Quote:
Seaknife hulls may be uncommon and little known but they are not experimental. They work (and they work well) according to the literature. I'm just applying this success to my own small boat design ... or trying to anyways. ![]()
I have an idea that may improve efficiency at low speed. I will post a rendering after I finish it. If it meets with favorable opinions here then it may resolve the low speed friction and drag issues
If these theories are correct then it seems to "makes sense" to retain the holes ... just in case the easiest way for water to get to the prop happens to be through the keel. Personally I think that some of the water through the prop will get there from within the keel, and the rest will get there from outside the keel -- but in either case it will get there via the path of least resistance. Am I wrong about this? If so please explain, thanks.
| Heliferry Concept - innovative boat design | foxxaero | Boat Design | 49 | 04-10-2012 02:01 AM |
| An Innovative System | amateur mariner | Propulsion | 21 | 11-05-2009 02:55 PM |
| Innovative method of increasing stability of the yacht | BTG YACHT DSGN | Boat Design | 13 | 11-06-2008 02:16 PM |
| Innovative Monohull Dinghy w/Buoyancy Pods | Doug Lord | Sailboats | 7 | 01-03-2008 07:15 PM |
| Backman 29-Innovative Canting Keel | Doug Lord | Sailboats | 11 | 11-23-2005 03:49 PM |
