#46
| Hi Randy, I was away for the weekend, so I'm just now replying. Quote:
http://www.boatdesign.net/forums/sho...167#post202167 http://www.boatdesign.net/forums/sho...442#post214442 Quote:
Regards, Doug |
#47
Not how I would have done it, but I understand your stated reasons, and the results are very good. ![]() I agree that the tip vortex will probably miss the rudder, however the rudder does operate in the downwash field of the foil (assuming foil and rudder on centreline). When I was designing RC sailplanes, I had a reference that gave an estimate of downwash angle at the horizontal stabilizer so the rigging angles could be designed properly ... alas I donated the book to a library and it has since gone out of print ... drat. ![]() How much do you think the dihedral angle of the foils costs you? I would imagine that the acute angle at the tip causes quite a bit of interference drag? Adding a spanwise extension was a very clever move. Again, great work there. A 'just do it' attitude is something that many of us could use more of! You inspire me to dust off some old sketches and apply what I've learned since I drew them ... my wife is gonna kill me ... ![]()
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
#48
1- Use lifting-line theory to estimate the sidewash at the daggerboard & far downstream 2- Choose a suitable function to blend between the 2 values Or, just as easy (for me, since I have the codes) : Modify either a lifting-line code or a lifting-surface code to calculate it. However, this will have to get in line behind a bunch of other calculations that I've been intending to get back to. Quote:
Doug Halsey |
#49
| once built a rigid leading edge flexiable double skin Sunfish CB with concave trailing edge and variable tensioning cable to change camber. Hard to see effect visually or in racing standard Sunfish, but forgetting to flatten camber on a dead run, capsized, showing some unintensional effect |
| Barrelback replica - increasing deadrise | carl_shipwright | Wooden Boat Building and Restoration | 12 | 04-21-2009 09:20 AM |
| Increasing Sail Area | dm567 | Sailboats | 6 | 01-10-2007 07:36 PM |
| Increasing the efficiency of Chine flats... | Aquatek | Powerboats | 11 | 08-31-2005 08:27 AM |
| Increasing LWL by 1.8 meters on Jeanneau SO 54 | zamibc | Boat Design | 1 | 12-18-2004 03:54 AM |
| Increasing Efficiency | 67-LS1 | Boat Design | 11 | 05-24-2004 08:15 PM |
