Old 06-03-2007, 06:17 PM
dblount dblount is offline
inboard well for outboard motor in a sailboat
i am looking for some information on building a well for an outboard motor on my sailboat. i would like to be able to raise and lower the motor with panels on the bottom to close the well when motor is not in use. any advice would be greatly appreciated. (motor will be 10 to 15 hp)
Old 06-03-2007, 06:55 PM
Rep: 2891 Posts: 8,798
There are a few engineering details you'll need to work out, but it generally boils down to a enclosed well, with a transom, set at the proper height for the engine (and well under the boat so it doesn't ventilate), a door or plug to seal the hole in the bottom of the boat when not in use and sufficient enough ventilation for the motor to breath and stay cool, without getting swamped or flooded as the boat pitches or has following seas pass under the stern.
Each application is engineered differently and the basics mentioned apply to most. Some don't use a door, others leave the top uncovered to help it breath. Some have fancy lifting devices, other just swing up on the outboards neck (which requires a lot more space). Of course, control cable routing can make things interesting if hand controls, other then what's available on the motor, plus a few other issues that can crop up and piss you off.
Old 06-03-2007, 07:04 PM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
Take a look at a Hobie 33. They have a system that seems to work well. There's a plug that drops into the well to seal it off, and the motor sits on top of the plug. The well is tapered and shaped so the plug aligns itself.
Tom Speer
Old 06-07-2007, 05:57 PM
JPC JPC is offline
Rep: 20 Posts: 90
This article might be of help/interest:
http://www.atomvoyages.com/projects/outboard.htm
The Henderson 30 also uses an outboard well.
Best regards,
JPC
Old 06-07-2007, 07:04 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Some clever boatbuilders have made a square, open box around the propeller, so that when you lift the engine vertically, the bottom of this square is closing the well flush with bottom.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
What Hull mods are required to use an Inboard motor Popeye Powerboats 12 04-23-2008 04:04 PM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 04:54 AM
mounting outboard to inboard/outboard pcromien Powerboats 25 03-03-2007 12:46 PM
Inboard or Outboard ??? Aquillaguy Powerboats 11 09-13-2005 01:04 PM
outboard vs inboard duluthboats Boat Design 24 07-16-2002 07:51 PM
