Old 12-10-2011, 11:39 AM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 707
I'm not sure about 'submersible' but this folding cat/tri/mono.....
concept has me thinking.
http://www.boatdesign.net/gallery/sh...hp/photo/20606
I could see this working as either cat or tri.....in combo with its retracted mono config.
Yes, I've seen other folding retracting cats and tris, but this concept has the hulls conforming when retracted into a mono hull.
Maybe a sailing cat or tri, AND a planing or displacement mono hull?
Flat outer hull outer sides, for correctly asymmetric sailing cat/tri outer hulls, which pivot inward to create a deep-Vee planing hull? Center hull would be either a narrow tri hull or "wave breaker" if a cat.
I don't think the odd shape of the cutouts in the center hull to accommodate the outer hulls would be too much of an INTERIOR design problem as boat interiors have been designed around the dictates of the outer hull all along.
I could see this working in about 20' open boat, as well as larger.
For larger boat where outer hulls would be living space you'd have to go with that crazy German(?) micro-apartment that is a cylinder that rotates to change the same space from bedroom to office, etc....so I guess whether you could sleep or write would depend on what the boat was doing.
Old 12-12-2011, 10:20 PM
upchurchmr upchurchmr is offline
Rep: 224 Posts: 526
Squidly,
Some things you should take as a joke, an artists imagination exercise, or the product of a 15yo transformer daydream.
Hopefully you did not draw this?!!!
Old 12-13-2011, 11:55 AM
Rep: 193 Posts: 707
I didn't draw it, but still has me thinking.
I could see it working as sail-cat and planing runabout.
Old 12-18-2011, 07:17 PM
FMS FMS is offline
Rep: 125 Posts: 233
The pared down version:
That spider boat is called the "Proteus"
From Mono to Tri Marvout Multihulls 21 09-21-2010 01:23 PM
yet another mono/tri question HeavenBound Multihulls 28 08-05-2009 05:26 AM
Convert Mono Hull to Tri? Kalagan Multihulls 19 06-15-2009 02:43 AM
Folding crossbeam design for tri erikhaha Multihulls 6 11-18-2008 12:27 AM
converting convential mono sail to tri-haul/outrig dem45133 Multihulls 9 08-10-2006 10:54 AM
