Old 11-23-2011, 02:48 PM
mhack mhack is offline
Rep: 10 Posts: 3
I'm looking for N/A to help design a small boat..
Hello guys,
I need help designing a small 14' power boat. Need a professional to make sure I do it right.
Thank you
Old 11-23-2011, 03:11 PM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
You must have some exotic requirements.
I find it hard to believe that most every configuration over the years has not been tried / done.
I would love to see what unique requirements you have.
Please post the written requirements & any sketch if possible.
Rich
Old 11-23-2011, 03:21 PM
Rep: 10 Posts: 3
Rich
Thank you for your reply.
Maybe I'm overthinking this, but It looks like an expert will not hurt my case
I would rather work in a private manner as I don't want to publish my design.
I'm assuming you are a N/A?
Is there a way to PM or email you?
My design involves small 14' x 4' deep-v 24 deg boat, with an outboard motor, 2 person capacity. Idea is to design a hull that would be comfortable and stable but also can handle "offshore" as much as possible, and design for that. For example maybe building a fuel tank in to a lowest point of the hull, narrow entry point etc.
Also I'm thinking of making it water tight as much as possible, so bow and stern sections watertight comparments and then a cockpit is the only open space.
Along these lines.
Power is by 25-30 hp motor.
Lightweight, possibly carbon fiber to some % of hull and/or balsa core.
One of the issues I've got is why with deep-v hulls some designers go with just V and others create what could be described as small steps on the side of the hull. Please see image. Does that improve stability static or dynamic?
Thank you
I'm looking for N/A to help design a small boat..-hulls.png
Old 11-23-2011, 03:50 PM
Rep: 94 Posts: 234
Possibly ?
You really need to test drive EVERY companies demostration boat / boats, at a lot of dealers. It is boring work. BUUUTTT
If you are serious to be better then 99% of that sized boat. You MUST pick something that is ALREADY FANTASTIC. Then SLIGHTLY modify that best of the best hull shapes.
Cheaper / faster & far more successful with time & money being spent.
I am not a N A. I am a excellent improver of updating old machinery to become competitive.
That is your goal also now.
Rich
Old 11-23-2011, 03:55 PM
Rep: 94 Posts: 234
I did forget to tell you to use caution in your offshore testing of a 14' boat as much as possible. That is a VERY DANGEROUS testing area in a approaching storm.
You are NOT supposed to be building a high survival rate Life Boat. Are you ?
Old 11-23-2011, 04:05 PM
Rep: 10 Posts: 3
No it's not a survival life boat.
The idea is to make it handle 2-3' chop, and be as safe as possible without turning it in to a submarine, it still needs to be a fun boat.
Still looking for a N/A..
this is the most unusal design for a small boat? billy91 Boat Design 1 06-09-2009 06:03 PM
Small boat design BWD Boat Design 6 09-14-2007 08:13 AM
small boat design wjt Boat Design 3 11-22-2005 05:22 PM
Propeller design of a small boat jmsurprenant33 Boat Design 0 09-21-2004 04:21 PM
small boat design Psycho D Boat Design 2 04-13-2003 11:41 PM
