| If an oars man rowed: Twelve miles in six hours with a 175lb boat, flat bottom medium rocker, and he weighed about 250lbs and tried to maintain around 20/24 strokes per minute. There was near 0 wind and only a few swells from power boats. How many calories did he burn?? If this is the wrong place for this, someone can move it for me. I looked around and didn't see a better place?? |
| Twelve miles/six hours= pretty slow. There are a bunch of variables to address. ...The boat must have been very short, something like an 8 foot dink, or he was rowing against a considerable headwind or current, or he was not putting much strength into his rowing strokes., etc..... 20 strokes per minute x 6 hours x 60 minutes = a lot of strokes. One would need to calibrate the question more completely to arrive at a reasonable approximation of calories used. If we knew how much pressure was placed on the oar blade, duration of pressure, and the lever ratio, we could make an educated guess at the amount of work done. That could be translated into calories or kilowatts or whatever. |
| A rowing machine gives 1670 for light effort (your criteria), 3300 for moderate effort, 4050 for vigorous effort and 5715 for very vigorous effort. Ball park figures for the same in your boat not fighting wind or waves would be similar. |
| I am not a high performance oarsman. I do it for relaxation and getting away. I am also trying to loose some weight. I stopped several times to rest, get a drink and even fished a little, one small bass, 1lb maybe?? Had lunch, salad, apply sauce, lime water. The oars are 7 1/2' flat bladed with a 27" in board. As to the pressure applied, very light? Was the 1670 for the entire trip? |
| Steve, How is the scow coming?? |
You could have 5 by 65g Mars bars or 20 average sized apples. Or whatever else takes your fancy to replenish. If you do not replenish then you will burn a bit of fat. If you do not eat ant extra then you will lose about 200g (say 1/2lb) each time you do it. Initially you will lose water so it will look good. You might even start to build a bit more muscle. The fitter you get the faster you move so you tend to burn more in doing normal things. Do it a few times regularly and you will get the endorphin rush. Rick W |
| So, the basics are, it is a better way to get in shape than to try to loose weight?? My right arm is weaker than my left, this is the main limit to my rowing power. I am a polio survivor. The difference will not change, even if I improve my strength. I do enjoy the rowing. It is a little funny, I had several people stop and check to see if I was OK. You don't see any row boats on the lake. I have had several people tell me it is the first one they have ever seen. |
| I try to do dedicated exercise daily and at present do one good run on the boat each week. I did 22km on Saturday in a little over 2 hours. Fuel cost was 3 Mars bars. But I reckon my boat moves a bit easier than most - I expect a lot easier than yours. Exercising on water is much more enjoyable than on land. Even if it is only going up and down a rowing course - I do prefer a few twists and turns though. Rick W |
| It is just a simple boat, sails very nicely. Rows easily but lacks directional stability when you stop rowing. Under power with the dagger board and rudder it is fine, but without them, it is a cork. I was thinking of fitting a skeg this winter?? ![]() |
| Mine is a bit more like a racing greyhound: http://www.boatdesign.net/gallery/sh...ze/big/cat/500 Your next project could be a pedal outboard - see video clip. A friend sent me the attached clip of a drive we worked on together. It is a lovely sedate action but you move swiftly because you are using powerful muscles. It is not particularly expensive to build. Something a clock maker should enjoy. Can be the next winter project. Takes a little setting up and attention to detail to get it to be reliable. I have the same pedal system in this boat but a conventional shaft rather than the outboard: http://www.youtube.com/watch?v=PYoW3XjHRbw Rick W |
| 80% done and 80% to go (mostly finishing) I hope to splash it towards end of September. I have one more day of vacation to burn before 14 oct. Blew through two other deadlines so hopefully this one sticks. Trouble is...I'm gonna be in the middle of moving during the next 10 days or so so those are probably a lost cause. |
__________________ Only shared knowledge can grow. |
Why not build a simple smaller, fixed rudder to attach to the existing rudder pintles to act as a 'rowing skeg' - a lot less work for the same effect. |
| OK! I have it figured out! I need to build oars. It is more work than using them! Thanks for all the input. |
| BHOFM: Your boat looks much like my own. Thus, I congratulate you for your impeccable taste in small boats. Flatties are deceptively competant. Goldilocks is more narrow than your boat appears to be. 37" at the chines. She rows very well, and goes sweetly and quietly with a tiny 23 pound thrust electric troller. About 4.8 kn at full throttle. The sail is a 59 square foot sprit boom rig that Bolger specified for his Gypsy. Not much sail for a 16 foot boat but entirely adeqate and demonstratedly capable of getting the attention of much more sophisticated sail boats of that size. When rowing I lash the tiller/rudder amidships. She goes where you point her. No skegs or skid shoes clutter up the bottom. I am also a BHOFM who has not lost much weight as a result of rowing. No doubt, I might shed a few pounds but for my recurring appetite for single malt scotch. |
| Making wooden oars? | thudpucker | Wooden Boat Building and Restoration | 12 | 11-09-2008 11:33 PM |
| building folding/breakdown oars | dude phukkyn | Boatbuilding | 0 | 05-13-2007 09:36 PM |
| Homebuilt Oars | baliano | Open Discussion: All Things Boats & Boating | 2 | 10-31-2004 09:19 AM |
| A Simple Pair of Seven-Foot Oars | Bob Smalser | Boatbuilding | 4 | 07-06-2004 06:20 PM |
| reinforcing oars | dgu56 | Boatbuilding | 0 | 04-18-2002 12:15 AM |
