| Unnecessary Complications is 48" at the chine and 51" at the shear and just under 12'. 222lbs in full sailing dress. That includes motor and battery. It carries 55 feet of sail in a leg o' mutton rig. My motor is a 30lb thrust and is more than I need. It has five speeds and I seldom use #3 unless the weather is bad. I spent the day on the lake, winds started out light but by the end of the day were 15/20mph and directionally stable. If I can get some just over 20mph it will plane in just the right conditions. It sails so nicely I don't want to do any thing to mess it up. I don't row that often so I can live with it. |
| Dont mess with success. I take it that "Unnecessary Complications" is the name you have given your boat. No doubt there is hidden signifigance in the name. My boat is too wide for a really good rowing boat, too narrow for comfortable sailing, but just right with the little electric troller. "Goldilocks" seemed appropriate. I once read of a man who commissioned the build of a cruising boat. Production delays, cost over runs, and various other nefarious difficulties was most annoying for him. He named the boat "ODTAA", abbreviating One Damned Thing After Another. One of the many racing dinghys in my past was a Laser. It was a bear to hold flat when going to windward on account of my sparse 160 pound weight. I'd be hurting after every regatta. The boat earned its name; Torturak. My A-Cat demanded a considerable degree of agility with its' single handed trapeze work. Elizabeth Taylor was a suitable name on account of the imagined scrambling of a Cat On A Hot Tin Roof. It never really had that name, but when it went really fast it was WHOOOOEEE! Keep on rowing, sailing, and funnin'. |
| Actually some one on this forum gave it it's name. First reply on this thread: Framed mast. ![]() I had seven boats named "The Good Life". Each was in a different language. My favorite was "A Bonne Vie" |
| When I was rowing a lot I had big problems in a breeze due to the high windage of my boat. I added a skeg (which broke off because I just glued it on) and then later I added a rudder. The rudder has more drag. I would really advise you to add a skeg, makes a huge difference in controllability and makes rowing much more enjoyable, with the skeg you can just concentrate on going forwards (backwards) without having to constantly adjust your rowing to take into account small errors in direction. Makes the whole thing more enjoyable. Keep at it and you will put on muscle. You have an advantage in that your boat is not too big, there is an ideal size for a one man rowing boat about 13 to 15ft and yours is close n peter evans |
| Making wooden oars? | thudpucker | Wooden Boat Building and Restoration | 12 | 11-09-2008 11:33 PM |
| building folding/breakdown oars | dude phukkyn | Boatbuilding | 0 | 05-13-2007 09:36 PM |
| Homebuilt Oars | baliano | Open Discussion: All Things Boats & Boating | 2 | 10-31-2004 09:19 AM |
| A Simple Pair of Seven-Foot Oars | Bob Smalser | Boatbuilding | 4 | 07-06-2004 06:20 PM |
| reinforcing oars | dgu56 | Boatbuilding | 0 | 04-18-2002 12:15 AM |
