Old 03-08-2008, 04:56 AM
Gashmore Gashmore is offline
Rep: 58 Posts: 52
Ideas for the head?
Sorry to divert everyone from the glory of hull design to the grunt work of the interior but I see no other place to post this question.
I am finishing up the heads in Rutu. Unlike a production boat where you mold up a one piece fiberglass unit and plop it in I had to build the cabinets in PVC foam covered in glass with solid surface counter tops and Formica faces. Used cockpit access hatches so everything is sealed up nicely from the shower spray. The problem is the flooring. There are hoses under it so there has to be access to it. I solved it in the aft head by building an over size shower pan and teak grate that can be lifted out. The forward head in the forepeak however is to small for anything more than a simple drain. Also about 3" of the hull is exposed on either side. Besides the hoses, this is the area most likely to be damaged in a collision with things like containers and whales so it has to be removable.
A lot of work has gone into this tiny space and it is looking really good. I don't want to spoil it with a clunky floor. I am looking for suggestions on how to make it removable, water tight and still look professional.
Old 03-08-2008, 05:59 AM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
could tou make the floor out of glass,,,on a work bench,,,,,make it so it will fit in either 1 or 2 pieces,,,then attach to flloor,,,when needed to get to unscrew and lift floor out,,,maybe,,hehe
hehe ,,,,,Jim------>
Old 03-08-2008, 06:03 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Watertight with a drain... A half bladder (pvc, polyurethane etc) Like a bladder tank cut in half upside down..
Old 03-08-2008, 06:24 AM
the1much's Avatar
hippie dreams
try a pic of the head,,,or whats there heh,,,,,,,but take the 5 gallon bucket out first
Old 03-08-2008, 06:36 AM
TeddyDiver's Avatar
Gollywobbler
I'll try
GM 7.4 head gaskets gonzo Propulsion 0 06-26-2006 11:43 PM
Head in the bow Seafarer24 Sailboats 11 03-20-2006 04:03 PM
The best marine head daveschile Boat Design 22 09-14-2005 08:43 AM
Cant get it out of my head Frosty Boatbuilding 8 08-28-2005 08:30 PM
Watch your head! daveschile Materials 3 08-24-2005 04:56 PM
