Old 03-03-2005, 10:34 PM
joebobb joebobb is offline
Rep: 10 Posts: 6
Ideal Power for displacement operation
How could one determine the appropriate engine size for a small motorboat (25' LOA and about 3 - 3.5 tons displacement) that would be operated at displacement speeds (up to about 6.7kt)? The hull is a round-bilge, semi-displacement hull.
Obviously, the boat would be expected to easily cruise at this maximum displacement speed.
Kind regards,
JoeBobb
Old 03-04-2005, 05:40 AM
Rep: 348 Posts: 2,579
6.7 is a bit high for a boat with a short LWL , many cruise at 1.15 of the Sq rt of the LWL to save noise /fuel/.
And old rule of thumb is 3HP for every ton of displacement or 5 hp per ton if your from the USA and have boodles of cash to burn.
A brigs or ONAN would be a gool long term engine , if youre into gasolene.
FAST FRED
Old 03-04-2005, 04:51 PM
PowerTech PowerTech is offline
Member
Rep: 4 Posts: 182
Yanmar 1GM 10 or a 2GM 20
Old 03-04-2005, 05:21 PM
Rep: 784 Posts: 4,841
Semi-displacement hulls are not economic at displacement speeds. For economy you should find the design's target speed.
Old 03-05-2005, 03:30 PM
CDBarry CDBarry is offline
Rep: 132 Posts: 521
Calculate the resistance using whatever standard method or model series that fits, select an optimum prop that fits on the shaft, see how much power you need to spin it.
Auto engine marinization DIY Marinizing 231 07-01-2010 07:34 PM
Option One - how big Willallison Option One 43 12-20-2005 05:44 AM
Power for planing vs displacement operation Tom_McGuinness Powerboats 10 02-02-2004 01:44 PM
Engine Longevity Willallison Powerboats 5 08-26-2003 09:13 PM
