| Ideal average angle of heel 20-30ft LOA I am curious what people think the proper angle of heel should be across the board going to windward. |
| There is no such thing. Each design type has an ideal angle of heel in different sea and wind conditions.
__________________ Gonzo |
| "There is no such thing" Forget that closed-minded approach. This is an across-the-board inquiry. This is a survey, like the census, everybody who sails has an angle of heel that they like, that makes them smile. I want to know what that is, and then reverse-engineer all the rest from that number. The shape of the chine comes to mind as a direct influence, and I am wondering about the spill of the sail, whatever sail that might be. |
| This is no reverse engineering, it is a stupid question. Read Gonzo, he is right. Lister
__________________ "I always like walking in the rain," he said, "so no one can see me crying." Charlie Chaplin |
| There is no proper so to say, On my past very stiff broad beamed motorsailer she performed best at between 10 and 15 deg of heel. Thats where she balanced out nice with a little weather helm at max. speed. It's a boat characteristic thing and often it varys between so called identical craft and as such makes the reverse engineering difficult but I see your logic in thinking so.--Geo |
My boat has a 2000 lb lead jet wing of a keel, yet lies on its side with the right amount of wind. I 'd say the boom goes in the water except I never use it: genny does it. I find this exhilarating, but passengers tend to find it frightening. Viking: 10-15 deg. Others: version 0.1-0.2 level answers |
![]() Here is an example of engineering from the angle of heel, which for this transat is 8-10 deg: "to windward they are slow and sail on a heeled water line around 8 - 10 degrees before you add yaw" Link I wonder if "yaw" means they fall over to leeward as there is so much less buoyancy up forward on a floating pie slice like a transat. |
| As little as possible. Trim the boat to go, not heel. |
| The average angle will be from about 5 of degrees to windward to 30 degrees to leeward, depending on hull form, sail plan, ballast ratio live or fixed and about two dozen more variables. Of course you could refine this a bit more by "splitting the difference, so your target is 12 to 15 degrees. Of course it's ludicrous, but it's a number to reverse engineer from, though a profoundly poor way to engineer anything . . . |
| Plank on edge cutters sail at 20-25 degrees on average.
| When the wife comes up wearing my dinner I know that its time to let out a bit. |
| Thankyou Daiquiri - i wanted to say something about that but wasn't sure what it meant version 0.1 and 0.2, or how to go about it. If it's using members postings as a sort of comparison or competition I ask Human 1.0 to please not involve me in such and to please retract and remove that part of the post. I'm sure it was just a knee jerk reaction which we can be all guilty of from time to time, but If one has a beef with a post then i feel it should be a one on one situation as it is uncomfortable to be put in the middle. All posts are opportunity to learn for both sides, in technical information and etiquette myself included. |
| best angle of heel is zero, you get the most sail in the wind, and the keel is most effective. Hence, the catamaran. Even they heel a bit, but they come much closer than any mono-hull. some of the modern racing mono-hulls have very long weighted keels that can be swung to the side can also have very small heel angle. Now that is engineering to the "ideal" heel angle! I think each design settles into a heel angle that is best for it, it was not intentionally designed to a certain angle of heel. As pointed out, there are a lot of different factors that affect it, and the designer usually selects the various design elements to meet other higher priority design goals, and the best angle of heel just falls out of the those choices. It is indeed silly to design a boat to hit a certain "ideal" heel angle, it would be a very poor choice to compromise ALL other aspects of a sailboat design to meet a certain heel angle. |
| Hydrostatic Properties at certain heel angle in Autohydro | petlily | Software | 2 | 11-23-2009 08:33 AM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 02:14 PM |
| Advice Needed In Calculation Angle Of Heel | sujith | Boat Design | 2 | 11-18-2005 02:54 AM |
| Static heel Angle Aproximations | budner1 | Boat Design | 2 | 05-15-2005 11:09 AM |
| Optimum heel angle | Blether | Sailboats | 9 | 06-09-2004 06:46 AM |
