Old 07-03-2009, 11:39 AM
Slipheed Slipheed is offline
I want to buy/have built a 150' trimaran.
Hi,
Who would build or sell a 150' trimaran? Any info would be helpful.
Old 07-03-2009, 11:59 AM
apex1
Build? every larger yard.
Sell? nobody, i doubt there is one at the market.
And: sailing, motor, hybrid?
Old 07-03-2009, 12:11 PM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
I believe that there has never been one designed that is that large. I am presuming that you are talking about a sailing craft. Therefore, you should consult a naval architect to design one for you, and he can then help you find a shipyard suitable to build it.
A 150' trimaran is going to be very wide, and lifting or slipway dimensions will be important. There may not be too many yards that can both build and launch such a craft.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 07-03-2009, 02:56 PM
wardd wardd is offline
Rep: 443 Posts: 925
simple solution, build at one yard and then move to another to launch
Old 07-03-2009, 03:05 PM
Rep: 501 Posts: 1,767
I would design it to be build in three pieces and assemble after launch....
Or build a very large dry dock first....
Apex, what do you think something like this would cost to make just hull only in Wood Epoxy?
Old 07-03-2009, 04:03 PM
apex1
We cannot build such vessel you know. Except for the smallest shop none of my yards are closer than 3 miles to the sea. We had even to launch our (by so far largest) 43m on the road! And that size multihull vessel is not designated to be built in wood epoxy, Alu would be the better choice! But playing some figures, why not. I guess you are not going to nail me down on my estimation and order it?
Just the hulls? Assuming a 45x7x1 meter hull and 20x2,2x.30 amas? OK?
hull about 95 tonnes, amas about 5 = 105 tonnes @ 55€ per kg when built in Europe = 5.77 Mio €
Compared: Alu @ 22.000€ tonne = 2,31 Mio €
Right.
Wood epoxy has its limitations............
Old 07-03-2009, 06:21 PM
I have seem large Tri's like 60' x 30' feet made from plywood and epoxied. So your saying Aluminum is cheaper... Also a lot lighter, better performance. Who would have thought. 43m by road... Wow.
Your talking hull only on price?
I guess you price will scare a lot of the dreamer around here into reality...
Old 07-03-2009, 06:40 PM
apex1
Well a 60 ft is a toy compared with 150" you know. And in the 60ft range wood Ep is competitive! But from that on Alu wins the race in terms of cost. Above some 100" or so I guess even in terms of weight. So, my comparison was not a "real world" one. But of course for a rough guesstimation it was enough.
And yes it was hull / deck only!!!
On top of that, if you would like to get it built by Abeking & Rasmussen, the builder of "Hetairos" one of the most (the largest?) sophisticated wood Ep vessels ever, you can easily estimate twice the price! The overall cost per manhour for a skilled shipwright is 65€ in Germany.
Regards
Richard
Old 07-03-2009, 07:31 PM
Rep: 527 Posts: 792
Why do you think they still build (most) airplanes in aluminum? Composite only competes with aluminum on weight or stiffness/weight when the composite is carbon skins over nomex honeycomb core. Fiberglass or wood/fiberglass won't cut it.
The all-fiberglass composite airplanes built by Cirrus all suffer from being overweight with poor useful load compared to the all aluminum Cessnas, Pipers, Socatas, and a host of others. It's less laborious to build in composite; at least for airplanes it is. So there could still be reasons to build this way but weight savings is not one of them.
Jimbo
Old 07-03-2009, 08:04 PM
apex1
Jimbo, not wood / fiberglass, wood / Epoxy in my case! And a good wood / Ep construction outperforms a fiberglass one in every single aspect. On smaller boats every other material except carbon composites too! It is hard to make a general statement for all those materials given. Even when we talk just about boats.
Regards
Richard
Old 07-03-2009, 08:23 PM
Rep: 527 Posts: 792
If wood epoxy could compete with Carbon on weight or stiffness/weight, then surely we'd still see a few racers built this way but alas, we do not. When F1 cars were still riveted aluminum and bonded aluminum, there were a few plywood cars (!) that competed pretty well, believe it or not. The plywoods were all hand made in place laminates,
but still it was freakin plywood!
But as soon as the carbon revolution hit in the early 80's the plywood cars could not compete any longer.
I'm going to build a wood Tornado one of these days, but I don't hold any hope of it being competitive with the fleet racers, which are all carbon/nomex.
Now the price/performance ratio is another matter! I know I can build my T for about 1/4 the cost of carbon by building in tortured plywood, and still get 90% of the performance of a carbon boat. But a 90% boat would finish dead last in a typical race, as you know
Jimbo
Old 07-03-2009, 08:46 PM
apex1
Ähh, sorry Jimbo, did you possibly miss or overlook a part of my post?
especially this: >>every other material except carbon composites<<
And I know already what plywood is............ I produce several hundred tonnes a year! Cold moulded.
Old 07-03-2009, 08:53 PM
Rep: 527 Posts: 792
Yes I did
Wood Good
Alum for zoom
Graphite Super Might
Glass is ass
Jimbo
Old 07-03-2009, 08:57 PM
Rep: 527 Posts: 792
Richard
The funny thing about this thread is that a typical tri has something like a beam 50% of LWL. That's the beauty of the multihull after all; all that righting moment from the beam. But can you imagine this guy trying to find a port He's going to have to park next to the cruise ships; no normal marina even has channels that wide!
Old 07-03-2009, 09:05 PM
Rep: 3125 Posts: 9,398
Come on folks, anyone truly capable of entertaining such a project, wouldn't be here, doing a touch me - feel me session. Someone tossed a bare hook and 'ya all bit.
1995 Mercury 150 HP toveri Outboards 0 05-25-2009 09:51 AM
glastron gt-150 amorris Powerboats 14 02-24-2009 07:09 PM
6.5kts With 150 watts Guest625101138 Boat Design 2 04-17-2007 04:33 PM
Trevira Core 150 guest12020101217 Materials 2 09-10-2004 07:58 AM
help on info about a 16' sea cat; to buy or not to buy? bc22 Sailboats 0 08-05-2004 11:29 PM
