Old 12-06-2007, 11:59 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Great Stuff is an aerosol can, single part foam, that skins over and is only suitable for sealing gaps in houses. In breaks down in sunlight. Marshmat posted that information 3 days ago. Great Stuff certainly will not be joining the small expensive club of closed cell, 2 part polyurethane foams that are impervious to water.
http://greatstuff.dow.com/greatstuff...here/index.htm
Pericles
Old 12-06-2007, 02:09 PM
tuantom's Avatar
tuantom tuantom is offline
Rep: 45 Posts: 177
I hope the 2-part polyurethane foams have improved over the years since I just filled about 16 cubic feet of voids in the hull of my boat with it. I personally know 2 people, plus myself (and I don't know that many boaters), who removed very heavy, water-logged foam from their late 70's early 80's era boats. Those two never replaced the foam and their boats have never been better (at least lighter and faster) - I was hesitant to pour it back into my hull; I'm still not sure if it was the best idea- but it's done and time will tell. I was very careful to wait for optimal temp and humidity to pour it, though it creates a good bit of its own heat while it's setting up - so controlling temp is hard.
What do they use for foam in buoys and floating piers? especially fuel piers. I think these would be good indicators of how closed cell it remains over time.
Old 12-06-2007, 11:03 PM
Rep: 3125 Posts: 9,398
Tuantom, the foams that were used in that era (1970's and early 80's) were not polyurethane and you're quite correct, they sucked like a hooker outside a GM assembly plant on payday (sorry, couldn't resist).
There are several manufactures of honest to goodness, marine grade, 2 part polyurethane foams, intended for floatation and extremely resistant to moisture, chemicals, fuels, etc.
Pericles, I get my foam from FiberGalss Coatings, Inc. (www.fgci.com) They have the specs available and also sell a 4 pound foam as well as the 2 and 8. You may also want to try Epoxy Products brand of foam too.
I'm in complete agreement on foaming in tanks (frankly a lot of other things too). It's a guarantee for future repairs at least, possibly causing much more then just a leak.
Maybe Rhino Coating the tanks (completely abated first), then foam . . .
Old 12-07-2007, 01:20 AM
tuantom's Avatar
Rep: 45 Posts: 177
Or use Pre-Kote on the tank and epoxy. They use it on airplanes in place of aladine.
Old 12-07-2007, 04:55 AM
Pericles's Avatar
PAR,
Epoxy Products, these guys? http://www.epoxyproducts.co.uk/
Pericles
Old 12-08-2007, 12:51 AM
Sorry Pericles, I misquoted the company name.
http://www.epoxysystems.com/products.htm
Scroll down to product # 425.
Great sail, great gale, a little carnage and lessons learned CharlieCobra Open Discussion: All Things Boats & Boating 9 11-20-2007 12:49 PM
"Great Stuff" for flotation foam? crasea18 Materials 2 04-23-2007 12:52 PM
Re-Thinking Propulsion Options samhales Propulsion 2 12-30-2006 07:43 PM
Great site here with great stuff... Gbenz Open Discussion: All Things Boats & Boating 7 07-18-2006 10:07 PM
Just thinking :) duluthboats Option One 10 10-24-2003 11:16 AM
