Old 11-20-2011, 04:16 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 707
I googled DDWFTTW and still don't get it.
Any help?
I assume we are talking about straight down wind, sustained steady state.
Once it goes as fast as the wind, what makes the prop turn?
I'd say the prop loses energy as the craft approaches wind speed and would become zero if craft matches wind-speed, and would require energy to spin the prop once past wind speed.
What don't I understand?
Old 11-20-2011, 04:26 PM
NoEyeDeer NoEyeDeer is offline
Rep: 155 Posts: 318
IIRC the prop is driven by the wheels at high speeds. I'll find the explanation.
Old 11-20-2011, 04:33 PM
Jim_Hbar Jim_Hbar is offline
Rep: 58 Posts: 40
Directly
Down
Wind
Faster
Than
The
Wind
You left yourself wide open on that one!
Old 11-20-2011, 05:56 PM
Rep: 155 Posts: 318
Here Squidly, see if thinking about this helps you. This is what made it all click for me.
http://talkrational.org/showthread.p...106#post976106
Old 11-21-2011, 12:06 AM
Rep: 193 Posts: 707
Wheels turn prop? thats diff. Still a brain teaser.
Any equations on all this? With LOTS of pictures and children's book style examples???
Old 11-21-2011, 03:26 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
These are the facts you have to consider, in order to understand how it works:
  1. When starting from the zero ground speed, the driving force is the aerodynamic drag of the vehicle (prop + mast + all the rest of it). So it is not difficult to comprehend how it can start moving downwind.
  2. When moving at any speed different from zero, the wheels-to-prop gear ratio is such that for every unit of distance covered by wheels, the through-air distance of the propeller is much higher than a unit. This is what allows it to get through the "windspeed barrier". When the vehicle is moving at the speed of the wind, the propeller is rotating at such speed that it still produces thrust. In this particular moment, the propeller gives a bollard pull, to use the nautical terminology.
It is convenient to remember a simple fact that, at any speed, the rotation of the propeller is driven by wheels through the higher-than-unit gear ratio.
In other words, the wheels provide the torque for the prop and the prop provides the thrust for the vehicle.
It is somewhat (just to make you comprehend it through a nautical example)) similar to a situation when forward throttle is applied to a boat moving sternwise (negative speed). The propeller will give positive (forward) thrust in every moment (even at negative speeds), while the speed will gradually change from negative to positive. In the moment when the boat moves through the zero speed, the prop will give the thrust equivalent to the bollard pull, and will keep accelerating to a positive-speed regime.
Hope it makes things more clear for you.
Cheers
Old 11-21-2011, 03:47 AM
Cloxxki Cloxxki is offline
Rep: 10 Posts: 28
It's like this.
Imagine a 15mē sail, or turbine, or even rear end of a big truck. It can extract a serious amount of energy from the wind.
Say, E amount of energy as wind speed V.
This amount of energy would propel a smaller vehicle, say a 1mē go-kart, to 3*V. If only you could get that big sail to transfer power to the quicker go-kart. ..
That's where the prop comes in.
The kart starts rolling in a tailwind, just like a landyacht would. The wheels are turning.
The wheels' axle drives the propellor, it turns much as on an airplane, hovercraft, swampboat, etc. It's geared such that it's thrusting air, throwing it back into the tailwind.
Due to the propellor "crawling" through the wind at an angle, it's going quicker than the wind. It doesn't have the speed limit V for a full open sail going directly downwind. It's like a gearbox for the sail. Each blade being a sail.
[The gearing between the wheel axle and the prop, pitch, etc, greatly affects the acceleration and top speed. In fact, if you change the gearing (and ideally mount a turbine-specific designed spinner, the cart becomes able to drive straight into a headwind. This is well-established, international races ar held for this.]
You'll see that the DDWFTTW cart itself is kept aerodynamic. It will be facing fierce apparent headwinds as it reached 3*V. It only has the power from the whole vehicle worth of tailwind. And there's some rolling resistance to deal with. The wheels may even skid a bit, due to the drag the prop tries to put on the wheels. On a slippery ice track, this won't work without spike tires, it needs the "braking" traction!
Let me know if I can help further. I *think* I understand it, and really, REALLY want to apply this stuff for the betterment of mankind, or general scientific fun projects.
Old 11-21-2011, 04:00 AM
Rep: 155 Posts: 318
Nope.
The cart relies on the prop moving less than one unit through the air. From the link I posted:
The way the energy works is that the the distance that that the wheels move across the ground is greater than the distance that the prop moves through the air (because the air is moving in the same direction as the cart). Energy is related to force times distance, so since the prop's distance is lower, its force can be higher than the retarding force at the wheels for the same amount of energy. The net force therefore accelerates the cart forward (until it's moving fast enough that other retarding forces balance it out).
Another reply in the same thread: http://talkrational.org/showthread.p...25#post1603725
Squidly: try Spork's jello block explanation in the next post after that one.
(Incidentally, Spork is one of the team that built the Blackbird. I assure you he knows how it works)
Old 11-21-2011, 04:33 AM
daiquiri's Avatar
Oh, it's so nice to discover that I didn't get a heck about it till now. Not that I've ever really applied actually, but still...
Thanks for the correction. Apart the wheel-to-prop gear ratio, is the rest of my post correct?
Old 11-21-2011, 05:21 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
think above under the search button of this good old forum you'll find the most info on "ddwfttw"
as well as the much easy'r to comprehend sailing straight upwind mills on the net
Old 11-21-2011, 05:48 AM
Rep: 10 Posts: 28
Harder to explain, but the Blackbird team is now aiming to reach >1* windspeed, directly upwind. www.fasterthanthewind.org
It will experience 2* wind speed worth in apparent wind when matching windspeed. Ride your bicycle upwind and'll hear and experience the wind blow harder than when stationary, right?
In their DDWFTTW attempts, at times they reached the same parameters. When going 3* wind speed DDW, the apparent wind is also 2*.
So, with the turbine specific blades and lowered gearing, it looks like they'll make it. Advantage will be that the rolling resistance will be only 1* wind speed, where they had nearly 3* in the DDW record.
Old 11-21-2011, 06:15 AM
yipster's Avatar
thx for the pointer Cloxxki
i did not check that blackbird before
Old 11-21-2011, 10:59 AM
Rep: 193 Posts: 707
OK, now I'm getting it after remembering my idea I had
as a kid to sail 'straight up wind' by connecting at least two sail boats with some sort of scissors so they would tack upwind towards and away from each other, but the frame would be going straight upwind.
Old 11-21-2011, 12:02 PM
Tiny Turnip Tiny Turnip is offline
Rep: 536 Posts: 256
http://www.youtube.com/watch?v=EEuAqq8FINw
I think this is the video which most clearly shows the transition between DDWSlowerTTW to DDWFTTW. Watch the streamers. If you haven't got the patience for the whole thing, the meat of it happens between about 2.50 and 3.30
Old 11-21-2011, 12:24 PM
Rep: 193 Posts: 707
I thinking of it as backblast from prop is getting pushed
by the wind as it is still slower(groundspeed) than the wind.
DDWFTTW - Directly Downwind Faster Than The Wind Guest625101138 Propulsion 414 09-08-2010 04:34 PM
an unpractical hull design only for ddwfttw boat sailor2 Boat Design 3 01-17-2009 11:03 PM
