  #46
Old 01-01-2011, 09:47 AM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,035
Originally Posted by Perm Stress View Post
Under mast, bending load is clearly the main load. But torsions will still be here. And will try to upset any open profile beam stability.
I would use just SS strut and wire or SS tape under mast. Beam is not efficient there as it has long span and limited SM (it can't expose under bridgedeck).
Torsion will be taken by bridgedeck and cabin.
  #47
Old 01-01-2011, 10:02 AM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
I beam is generally suitable for materials with high shear strength and shear stiffness. It generally mean metal. I did not hear much about I beams made of composites...
All the stresses in my designs are 95% of permissible.
  #48
Old 01-01-2011, 10:07 AM
Alik's Avatar
Yes, there are some T-bars in composites, not I-beams. For composites, better use square pipe or top hat sections that makes it easy to produce leaving no open edges.
  #49
Old 01-01-2011, 10:11 AM
Rep: 323 Posts: 523
My guess if beam is used, it would be embedded in bridgedeck structure; than bridgedeck would take care for stability/buckling) of beam, among its other functions.
If structure in its entirety is made from materials/members with significantly different stiffness/strength (glass/carbon for example) properties, FEA would be in order, to eliminate uncertainties on interaction.
  #50
Old 01-01-2011, 10:17 AM
Alik's Avatar
It is exactly what we have done, but we used top hat section between bridgdeck plating and cockpit deck. Still flexible.
  #51
Old 01-01-2011, 10:50 AM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Vessel Substructure to Support Rigging Loads
You might have a look over here...one of the smaller racing cats on that Swiss lake that was the predecessor to the Alinghi America's Cup catamaran
...lots of creative support rigging ...underneath
Sail Loading on Rig, Rig Loading on Vessel
How fast can Alinghi's huge cat be?
  #52
Old 01-01-2011, 10:54 AM
Alik's Avatar
Thanks, interesting reading.
CMD "project Zeus" VS VOLVO "IPS" gerard baladi Pod Drives 13 09-10-2007 09:23 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion: All Things Boats & Boating 0 08-08-2007 04:43 AM
Westlawn ? "Lite" versus "Module 1" MikeT Education 2 10-10-2006 12:13 PM
"Free" 3D modeler "similar" to Rhino CGN Software 0 05-14-2006 10:56 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 02:03 PM
