| Hydroplane I would like to build a hydroplane that would be able to achieve somewhat of a plane with a 3-5hp motor on the back but be able to accomodate up to a 10hp. If this is possible, does anybody have plans? If i were to build one from scratch, what type of wood would be best? I would then cover whatever material with a fiberglass sheet and marine epoxy. Last edited by dmgetz14 : 01-31-2012 at 05:37 PM. Reason: Other Questions |
| Gonzo said you need 1 hp for every 40# to get up on a plane, so if your, the motor's and the boat's combined weight is over 200# you probably won't plane with 5 hp. One of many sources: http://sandypointboatworks.com/hydroplanes.html This boat empty weighs 120#: http://sandypointboatworks.com/Minim...ydroplane.html
| Rob White and Sons have plans and instructions for a 16 foot by 43 inch stripper that claims to plane two adults with 4 horse power. I'd be skeptical if the claim was from someone else. Robb, now deceased, was a most inventive and industrious guy who pretty much proved his claims. In this case I think that the boat will do what they say. Check this out at www.robbwhite.com Last edited by Boat Design Net Moderator : 02-02-2012 at 05:49 PM. Reason: < URL robwhite.com updated to robbwhite.com > |
| I built a 10' racing pram about 15 yr ago, it planed at about 12mph with a 5hp air cooled Sears engine. |
| I never weighed it, but I would guess about 125#. It was 1/4" plywood. I would post a pic, but it is not on the net. |
| Boat 125# Outboard 35# Boy 80# _________ 240# Again, these are guesses leaning to the heavy side. ![]() |
| The MiniMax should plane with 5hp at 10-15mph, depending on your weight. Would be better with 10hp, though.
__________________ /Jimboat AeroMarine Research 'Secrets of Tunnel Boat Design' book 'History of Tunnel Boat Design' book 'Secrets of Propeller Design' book 'Tunnel Boat Design' software w/'Vee hull design' & 'Porpoise Analysis' 'PropWorks2' software 'Vee Hull & Vee Pad Design" paper 'BoatDesign.net article on Tunnel Boat Design" |
| So, you got it to plane with 48# per hp. I can see that happening. My first boat did about 10 mph with a 5 hp sears but I weighed about 142# with 24 sf flat bottom and angular bow to total length of 8 ft. total weight of hull was ??? I don't remember. ![]()
| check this out www.ccwbra.com/ Relative new class that uses 6 HP Evinrude/Johnson 2 stroke outboards as the only allowable power. |
| There's a whole section of hydro planes here including Minimost, Minimax, etc... http://www.svensons.com/boat/ |
| I have an 18' foot canoe that will plane at 18knots with 2 relatively overweight guys on it. SO that is 160lb for canoe and engine, and about 400 for OW guys. So 560 lb with 5hp. |
| Racing hydroplanes I've built many c-stock, d-stock,and fe class in the 80's and 90's. The boats must be built light, okume ply & okume sticks. Ply is 1/8" max. C-stock will reach a speed of about 70 mph. The FE or formula E will reach 135. Don't know were to find good plans anymore. I quit racing because the Ins. just got to high. Hope this helps...Michael.. |
| Vintage Hydroplane? | sawzall | Boat Design | 1 | 08-01-2011 10:35 AM |
| RC hydroplane | Letniq | Multihulls | 3 | 08-07-2009 04:26 PM |
| Picklefork hydroplane | F3RR3T | Powerboats | 10 | 08-06-2009 08:07 PM |
| Building a hydroplane | glenn effison | Boat Design | 2 | 04-29-2009 05:26 PM |
| hydroplane design | afrhydro | Boat Design | 0 | 08-10-2008 08:08 AM |
