| Hydrofoil for Pontoon Boat I am looking for a way to speed up my pontoon boat a bit. In searching all of these threads on adding third pontoons, lifting strakes, etc, I came across this fascinating idea I will quote below... In researching these, it seems I can put a foil between the pontoons at around the center of gravity, and get some major lift. Making my big pontoon come up on plane to some extent and bring more speed and fuel efficiency. Id have tried to contact this person through email, and he may still get back, but I wonder if any of the rest of you have thoughts on how I should go about fabricating a hydrofoil for my pontoon. I have access to a sheet metal shop with a lot of different equipment and capabilities. My brother in law is really good with this stuff and he can basically build whatever I need...but I don't exactly know what I NEED! Boat Info: 2001 Crestliner Pontoon 60hp 4 stroke Mercury 2 pontoons 23" each Dry weight 2000 lbs My questions are: What size What shape Where to position (ie how do I locate the center of gravity on my boat) Any ideas? Thanks in advance... ![]() ![]() ![]() Quote:
| foil assist You might get the book: "Hydrofoils Design Build Fly" by Ray Vellinga. It is the bible for hydrofoil experimenters.You can probably find it on Amazon or PM me for further info. You could also contact Ray-probably after you go thru the book pretty thoroughly since he has built many hydrofoil powerboats. Keep in mind that what you're asking for requires a good deal of engineering just to determine the feasibility of the project then it has to be very carefully looked at structurally-preferably by an engineer. Good Luck!
| Again, SlowCruise, you can't add weight, drag and screw up the flow to the prop, then expect anything else, except slowing your boat down. You can't get something for nothing. All planing craft are power verses weight and hydrodynamic efficiency. You know your hydrodynamic efficiency is on the crappy side of things and you weight is about average, so you need a bigger engine. It's not an especially difficult set of variables to consider. Wings and extra pontoons might (if well placed and shaped) change portions of the ride quality possably, but you will slow down, not speed up. |
| Par is telling it like it is. Please do not be insulted if I suggest that you are seeking to make a silk purse from a sows ear. This is not to insult your boat but to address reality. Boats with round pontoons are more efficient at very low speeds because there is less wetted surface for a given displacement. For speed we have to forego the very low speed efficiency for more dynamic forces that are involved in lift. For speed, a flat or rectangular section is decidedly superior to round ones. More economical to operate at speed too. There was a Florida outfit who made pontoon boats with rectangular, near flat bottomed sections. They were more efficient at speed, required less power for a given speed and weight. Alas I think that they might have gone under. Why? Everybody knows that a pontoon boat must have round sections as a result of divine decree. Wrong! Consider that you might weld on some channel sections, the same width as the round sections, to the bottom of your cylindrical pontoons. Now you have a flat running surface. By all odds it will go faster with the 60 HP that you have.......unless you have it overloaded with all the weighty creature comforts that we all appreciate. This would be a simple, straightforeward improvement in speed potential. It still may not live up to your hopes and desires. If it were my boat I'd do it in a heartbeat. Simple, cheap,not likely to diminish present performance. One caveat. At the front end of the channel there should be a sled like transition from rectangular to round. That is not a challenging layout feature. Close the rear end of the channels too. The boat will float higher in the water now. You might have to lower the engine a tad, maybe not. |
| Messabout - could it work this way? I'm a little murky on your proposed layout. What if I just created lifting strakes on both sides of each tube to achieve this flattening effect? If that what you are describing? (This would allow me to use the same trailer and not have to modify it.) I'll attach some pics so you might comment on the size only. I understand that you would have me seal them up and enclose the end there. I would definitely benefit from the added floatation. And then rounding those into the tube and upward at the front? Or how exactly would I do the front rounding "sled" thing? Last edited by SlowCruise : 12-20-2011 at 07:48 PM. Reason: more details |
On a hard chine boat, it would be a chine to separate the flow to assist in change from hydrostatic to hydrodynamic region. In a nut shell, to get lift you need 2 things, 1) area and 2) speed. You have neither to achieve your objective. All you're doing is adding drag. Those spray rails shall never be above the running DWL as a spray rail/chine should be, thus just adding drag. You should re-read PAR's comment again. Dont break what is not broken!...if you want to go faster, you need a totally different hull form. |
| I've always been curious about this one. What if he's talking about displacement speeds tho. would the foil offer enough lift at lower speeds to reduce the wetted surface area and offer less drag overall. At say 10 knots, OK at 2 or 3 it might reduce efficiency but at say 6~10 it might improve it. I realize he specifically quotes on planing forms but if it was just a displacement hull wouldn't a foil tuned to some specific speed range offer enough lift of offset its drag cost. The arrangement of a straight foil between the hulls just seems to good to not work. Better yet two. One for and one aft, so there's no delicate balance to screw up.
__________________ I am skeptical of the deniers diatribe |
| I have looked at the benefit of foils on displacement craft before. It seemed that with a foil L/D ratio of 15:1 the "weight savings" effect on the displacement hull was still equal, only now with the complexity of a foil. |
| no appreciable gain in performance eh. Ok I guess that answers that was there any savings in the structure of the boat. IE did the fact that you now had a connecting rod low and high equal more of a truss system to suspend the pod between the hulls making for an overall lighter support structure. one big beam spanning x is always heavier than a truss. Could the foil be used in a truss system to help save some weight thus making its existence a worthwhile component of the system I've also wondered about pitch dampening with a foil or foils. Would the lack of vertical motion translate to less power lost to other than forward motion ?
Boston, here is a paper on Hysucat development where lifting hydrofoils were applied to planing and semi-planing catamarans with significantly good results:
| I wonder if this is any good? http://www.pontoonwaterglide.com/index.asp
Looking at those hulls, the distance between them is roughly, guessing 1.50m Lets say you have a foil that spans, and you wish to get max lift possible, but min drag…so the typical 15:1 is that of say a simple section to make a NACA 0012. If you go for broke and make the chord say 500mm, at 10knots you’ll get around 450kg of lift, great. So at 15:1 drag is about 30kg…and frictional about 10kg…great…all looking good so far. So, let’s look at the structure. On a 1.50m span lifting 450kg, using a suitable FoS of taking fatigue into account, for longevity, not the quick 5min wow factor….this gives you a modulus of 552cm^3. A naca 12 section with a chord of 500mm, mean max depth of section is around 60mm, not much. Even being very “optimistic”, trying to get simple thickness of skins with a say 350mm section at say 25mm centres….you aint gonna do it! There is insufficient depth and/or strength in the aluminium (even if the skins were 25mm thick, ie solid ally, you only get around 280cm^3). Which means going to exotic materials for the strength, since you need a material property that has a high tolerance to fatigue and high fatigue limit. ….which means very expensive, more than the cost of you boat! With boats, it is either hydrodynamic or structural reasons why most of the “that’s a good idea” fail, sadly. |
| this might be a completely stupid question but the drag effects the power needed to generate the lift. But the lift still lifts and reduces the immersed area of the hull, reducing drag. So don't you end up still getting the lift but it cost a bit more energy to get it up to lift off speed? But then you save energy at a displacement cruise speed ? Maybe I'm clinging to a bad idea on this one but it just seems, as you said,. like such a nice idear ![]() I can see where there's an obvious trade off but who knows, just thought I'd ask. Thing is some folks seem to hate foils and some folks are stupid for foils and I'm always wondering if that doesn't taint some of the stuff I read about them. If you go to a foils site they act like its gods gift to the world. If you listen to most naval architects they all seem to hate them. But there must be some practical application for these things somewhere
The foils have a limited applicable, and as you say, you either love them or hate them. |
| oh well, another one bites the dust ![]()
| Small DIY outboard hydrofoil boat | nord0306 | Boat Design | 3 | 08-24-2011 12:21 PM |
| I want build a hydrofoil small boat. | abdhaneef | Boat Design | 1 | 12-02-2009 06:54 AM |
| aircraft propeller on hydrofoil boat | haybayian | Boat Design | 16 | 11-21-2008 06:57 PM |
| pontoon boat | cat chaser | Boatbuilding | 51 | 11-01-2006 01:32 PM |
| 8' pontoon boat | Boatbuilding | 16 | 04-30-2005 08:56 AM | |
