  #31
Old 02-12-2009, 09:39 AM
aka Terry Haines
Rep: 1682 Posts: 2,818
I'm not a hydraulics guy but worked on the electronics of several installations: if the parts being conected are not moving with respect to each other it's a lot cheaper to use the solid tubing with the compression fittings as Frosty suggested. Also, don't overspecify or use a non-standard pressure, use the closest standard.
Dances with Turkeys
effeciency loss question about hydraulics/generators ijason Boat Design 8 01-26-2009 02:14 PM
Low Pressure Hydraulics brian eiland Boat Design 1 07-29-2007 11:43 PM
Hydraulics for main sheet trimming? Omeron Sailboats 8 05-28-2007 12:54 PM
lifting keel mechanisms- hydraulics? water addict Sailboats 16 01-01-2006 12:16 PM
Fuel, water, black water tank construction kudu Boat Design 12 07-25-2003 07:54 PM
