Old 07-19-2010, 03:29 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Originally Posted by Wynand N View Post
stable ....hard chine flat bottom or hard chined V bottom?
Might be something of interest in this old thread:
Lost power in heavy seas - which hull shape?
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 07-19-2010, 09:19 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
Originally Posted by daiquiri View Post
Hi Terry,
Please find attached a sample dialog screen of Freeship's SSD command. I've circled in red the dialog box where you input the Zcog, and the graph where you read the calculated curves for various Zcog.
As for your second question, it can be corrected manually too - and it is not so difficult. The formula is:
GZnew = GZold - Dz sin(Heel)
where:
- GZold is GZ at the initial vertical position of the CoG, for a given heel angle
- GZnew is GZ for new vertical position of the CoG, for that heel angle
- Dz is the vertical shift in CoG, positive when upwards
- Heel is... the heel angle.
The effect of a horizontal (transverse or beamwise) shift of the CoG is evaluated in a similar manner:
GZnew = GZold - Dy cos(Heel)
where Dy is the transverse shift of CoG. It is positive when contributing to the heeling moment, negative when contributing to the righting moment (canting keel, for example, or a sailor on a trapeze).
Hope it was clear enough. Cheers.
If you are using the original FreeShip...this is not available. You must download FreeShipPlus. Freeship does not have the SSD and the screen that you show. Therein perhaps lies the confusion.
Old 07-19-2010, 11:48 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Yes, so I discovered! Oddly, I thought I had created a post thanking Daquiri and noting the problem, but it somehow vanished into cyberspace. The lack of SSD/DSD curves is not a big problem however, as it is simple to make manual corrections. Thanks to both of you for the help!
Dances with Turkeys
Old 07-20-2010, 02:42 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Oh, I thought indeed we were talking about Freeship+ .
I never understood what's the difference between the two anyways...
Old 07-20-2010, 01:35 PM
lewisboats's Avatar
Obsessed Member
FreeShip 2.6 is the last version of the original by Martijn...FreeShip+ is a continuation with additional features added by Victor T...mainly in the resistance area but also with stability as we can see.
Old 07-20-2010, 04:33 PM
aka Terry Haines
I now have the Plus version, thanks for the help!
Dances with Turkeys
Why so stable? catsketcher Multihulls 17 03-08-2010 10:04 AM
Is progeCAD Stable alidesigner Software 2 08-06-2008 11:54 PM
Type of hull please? Edmund Boat Design 6 08-08-2006 02:12 PM
Type of hull ? David Cowen Fiberglass and Composite Boat Building 3 10-24-2004 06:09 PM
Hull Type jigsaw Boat Design 3 04-21-2004 09:15 PM
