| Hull Type Hello, I am new. I need help in id this hull type. Is it a semi-v or semi flat or what ever. i am ignorant to this info. The pic below does not show the bottom but it is flat till you get to the bow then has a v hull like shape. The stern is square. ![]() |
| Onthe upper right-hand corner fo the transom, there should be a number, rather like the VIN on a car, but called a HIN. THe first three letters will at least tell you who made it. Google HIN and it should pop up with the USCG site that tells you the mfr. Steve |
The company that made this boat is Master Marine ( Good go Sports) they are no longer around and only being made in Korea now. I have almost all the info about the boat. Just trying to figure out if its a semi-v or what. I am not too familiar with hulls, I know the v and flat and thats it. |
| Why is it important? The type hull will make little difference to a novice or someone not to up on hull design. Most planning hulls are a modified "V" form of some sort, the "sort" part is really not important, unless you are making a study or are rather knowledgeable on the subject. My guess from the very limited photo is a modified "V' form with reversed chines and lift strakes. Though the very bluff bow would suggest a knock off of the BW form, who knows with a photo like this . . . |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 01:20 AM |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 04:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 06:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 09:51 AM | |
| Stepped Hulls | Ryon Macey | Powerboats | 53 | 08-01-2004 10:44 AM |
