Old 07-15-2008, 12:55 PM
Jasper_ghost Jasper_ghost is offline
Rep: 10 Posts: 16
hull with tunnel
I just found a pic of a Penn Yan hull with a tunnel. This 33ft hull should have a max speed of 28knot. But what is the advantage of this tunnel. Lower planning speed or better stability? or maybe better fuel efficiency...
Old 07-15-2008, 05:47 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Shorter turn radius at speed, less choppy ride maybe
Regards
Fanie
Water ! Just gimme water !
Old 07-15-2008, 11:21 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
My guess is that the hull was intended for two motors with the props in the tunnels and someone put a single motor in instead. The virtue of the tunnels with twin motors would have been shallow draft, which it certainly doesn't have with a single.
Old 07-16-2008, 08:02 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
What Gilbert said. The tunnels were for shallow draft originally. It would be better if the tunnels were filled in now.
Tom Lathrop
Old 07-16-2008, 05:07 PM
Rep: 10 Posts: 16
Thanks. I was just thinking if the tunnel horisontal ared had the same function as a delta pad but with lift seperated from center to give better stability.
Another Q.
This 33ft boat weigth approx 6000kg/13000 pound.
What will be the most economic speed (engine is a Volvo Penta 370hp TAMD63 diesel). Any good guidelines for how to calculate a fuel consumption vs speed.
Old 07-17-2008, 05:20 AM
Rep: 756 Posts: 3,328
High idle , 800 rpm or so is best for range.
After that you are traiding speed for distance.
Next "best " is usually just above plaining speed , but it will cost at least 3 to 5X as much per mile in fuel.
FF
Old 07-17-2008, 09:24 AM
Village_Idiot Village_Idiot is offline
Rep: 75 Posts: 238
With regard to the tunnels:
Tunnels are basically good for shallow draft only. If you do not need shallow draft, avoid the tunnels as they generally hurt all-around performance, except in the rare case of high-performance racing tunnels. With a tunnel, you lose speed, agility and reverse thrust.
With regard to the tunnels, especially on planing boats:
Tunnel boats, especially pocket tunnels, can be a huge pain to set up correctly. Once they are dialed in, they are a thing of beauty with regards to their focused performance potential (being able to run in extremely shallow water). There are 20-foot-plus, 2000-pound-plus tunnel hull boats out there with motors up to 200hp and beyond that can run in less than ten inches of water, some in quite a bit less.
Retro tunnel hull? ted655 Boat Design 0 05-06-2008 03:48 PM
11' tunnel hull woodman Boat Design 2 12-16-2007 02:19 PM
Tunnel hull questions Mrdennis Fiberglass and Composite Boat Building 0 07-11-2007 10:30 AM
Tunnel Hull Inflatables flyingdux1 Open Discussion: All Things Boats & Boating 0 12-14-2004 11:16 AM
tunnel hull midnightkayaker Boat Design 1 02-20-2003 08:49 AM
