  #31
Old 02-19-2011, 03:40 PM
Rep: 1493 Posts: 7,447
The tunnels also cause loss of lift and more turbulence. I think that the only real advantage is less draft.
  #32
Old 02-19-2011, 03:48 PM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
It is certainly two sided process: something you win, something you lose.
Properly designed tunnels do not cause turbulence, by the way.
The break point could be the required amount of lift -the deeper in pure planing area you are, the more important the lift becomes.
All the stresses in my designs are 95% of permissible.
  #33
Old 02-26-2011, 09:09 PM
PCVdominica PCVdominica is offline
Rep: 10 Posts: 3
@ Perm Stress: The equation you posted ~10-13kW/t, does t=ton(s)? Does that equation have a name?
Thanks for your response to my above questions =)
  #34
Old 02-27-2011, 01:20 AM
Rep: 323 Posts: 523
Yes, t mean tons.
The equation has no name really.
A while ago I did statistical analysis of published data for various motor yachts; comparison between installed power and Froude number, based on quoted max speed was made.
It was necessary to decide on ballpark figures for speed and power of large motor yacht design.
At limit semi-planing/planing there was 10-13kW installed power per ton of quoted full displacement. That's all.
P.S.
all the data used for analysis as published:
published max displacement
nominal power of engines
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
speed & Trim angle curve by maxsurf, hull speed Joe Lu Software 1 11-25-2004 06:37 PM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
