| Hull shape - hull speed? Maybe a dumb question but what better place to ask a dumb question than a room full of smart people!?! As I understand it, the formula for hull speed presupposes a more or less "conventional" shape. My question has three parts. 1. Is a narrow hull with a fine and low angle entry able to achieve higher speeds than a wider blunter hull? 2. Is there a relationship between the actual measured length of the hull at the waterline and hull speed that is different than the relationship between the straightline measurement from lines extended from entry and exit?(did I mangle that description?) 3. Is there a site or book anyone could recomend to a lay design enthusiast to help me understand such things? Thanks In advance! Paul |
| In short, a displacement hull speed is rooted in the waterline. A simple thumb rule is that the boat would do about 1.3 times theorotical hull speed. However, because of different hull shapes, this is not always true - therefor actual hull speed can varies from about 1 - 1.6 times approx theorotical hull speed. yotphix, there are a lot of issues that have an influence on hull speed, but in essence friction and drag are the main critters slowing a hull down and this is directly a result of wetted surface area. Another issue that will make a hull fast or slow is the foil shapes of keel and sailplan. High aspect ratio's generates more lift that low aspect ratio's - ever wondered why a glider's wing is so narrow and long? I believe they would make it narrower still if they can find a way of attaching them safely to the fusalage! Another indicater of hull speed is the ability of the hull to carry it's sail, and so we can go on and on.... There are some good books available; check out the book store on the top of this page ![]()
| Thanks Wynand, I hadn't heard that 1.3 figure before. Am I right to think that the function normally referred to as hull speed is related to the length of the bow wave - a wave's speed being a function of it's length? Is my perception that a dispacement hull has begun to exceed this speed when it begins to sit lower in the water and the bow wave begins to ride higher and higher on the hull? It seems to me that with adequate power (strong breeze, large sail area) all of the friction or wetted surface issues can be overcome but that the length of that wave is the true limiting factor. Unless maybe a finer entry with a long taper (like the Dashew boats) creates a bow wave differently? I have also seen the size of a wake referenced as an indication of the "efficiency" of a hull. (Albeit in a lesser forum! Who knows what value?) Any thoughts? On the topic of high aspect ratios generating more lift, why then would a plane like a DC3 or a deHavilland Beaver, two real workhorses with great load carrying capacity at low speeds have such low aspect ratio wing designs relative to a glider? Is that perhaps because the advantages of high aspect ratios where poorly understood 50 years ago? I have read a bit about the Dashew boats recently and have been moored in Newport Beach California for a couple of months where I have seen Deerfoot, some sundeers and a number of Macgregor 65s. It has made me quite curious. Thanks again! |
| The nature of the wave system generated around the hull is the stranglehold which inhibits planing and is an important factor affecting the performance of displacement craft. As it moves through the water, a boat's hull produces both transverse and divergent wave system, although only the former appears to affect the resistance of the hull. The transverse wave system results from the interaction of the bow and stern wave systems, and varies with the boat's velocity. At maximum displacement speed, the hollow of the stern wave is reinforced, causing the boat to trim up the bow (squatting the stern), a state which carries a lot of resistance. A boat's velocity with reference to its wave system and lenght waterline is judged by a Froude number. Maximum displacement speed is indicated by a Froude number of about 0.4 depending on the hull's displacement length to be more accurate than the rule of thumb method of approx 1.3 LWL. However, take note that wavelength is determined by velocity, and not the hull's lenght. The quest for good performance starts with the shape of the hull, particular below the waterline. It pays to maximize displaced LWL, thus enhancing the hull's capability of generating a longer wave system by a bow wave which forms earlier and a stern wave which extents as far aft as possible. Overhang at the bow causes the bow wave to creeps forward, and because the of the sectional form usually produced by the overhang, the displaced lenght is increased substantionally when heeling. A full bow generates an earlier bow wave, though the same effect would result from a deep forefoot which retains reasonable waterlines forward. In general, this is achieved by an increase in volume of displacement forward. if taken to any kind of extreme, however, additional drag would result owning to the size of the bow wave formed; a problem usually encountered with full bows. To achieve a bow wave shift, whilst at the same time bringing about a possible reduction in the height of the bow wave, lies in the use of the bulbous bow, but that is another story.... ![]() BTW. I have some photos somewhere that shows a model of a displacement hull and its wave system created from low speed to max disp speeds. If I can lay hands on it, I will post it.
| yotphix, here are the photos to demostrate the wave system created by the velocity of a displacement hull.
| To make sure that I understand correctly, Displacement Length is the actual or perhaps, DEVELOPED distance from stem to stern at the waterline? The pictures are great. It looks to me as though the second last photo shows one complete sine wave whose length is one boatlength. The last photo the boat is doing what I asked about previously; sitting lower in the water and not bow up stern down but actually lower fore and aft. Perhaps this is the effect of the overhang you were refering to? the boat is actually getting longer as it puts the wave higher on the bow? Something like that. Good Wynand this helps! Thanks so much, Paul |
Wynand N and Jhardiman have given a good explanation of the most important wave-making factors, but there are also viscous effects that are significant, particulary for small hulls travelling at Froude numbers below about 0.5. Here are some scatty notes to show you that you are not alone in your ignorance. We are all bozos on this boat! There are three very important viscous factors (along with several others I won't mention now) that affect wave-making: the stern-wave detachment point, the boundary layer (BL) separation point, and the shape of the streamlines near the stern. Havelock, Inui, Maruo, Beck, and many other notable ship hydrodynamicists have investigated these aspects, however they are still regarded as very poorly understood. In an interesting report of experiments performed in Japan during the 1980s, Doi \cite{Doi80} and Kajitani \cite{Kajitani87} presented photographs of stern waves produced by some small model hulls. Those photographs show that stern waves begin at different places on the hull (forward of the stern) depending on the Froude number. At some Froude numbers the starting point is close to the stern, at others it is further forward. The situation is, as you can appreciate, more complicated for multihulls where waves created by one hull can cut across the other hulls. The detachment point is not the same as the location on the hull where the BL separates, rather it should be regarded as a point where the BL begins to thicken rapidly due to the adverse pressure gradient as the hull curves inwards near the stern \cite{Maruo76}. The shape of the streamlines near the detachment point can have a significant effect on wave-making, but we know very little else. On well-designed hulls, the BL separation point is close to the stern, usually within about 5\% of the hull length. We know almost nothing about the wave-making due to BL separation near the stern. Stern waves have been observed to begin as far back from the stern as 20\% of hull length on some small models \cite{Kajitani87}, although it should be said that the S103 Inuid hulls used in those experiments are not good representatives of real ship hulls. The ``stern wave starting point" is not necessarily identical to the detachment point, but it is an indication that viscous effects are important at that location on the hull surface. In my program Michlet, I have tried to account for this effect on hulls with transom sterns below Froude numbers of about 0.35 but I wouldn't bet a family member on the accuracy. (Ok, maybe the teeenage male if the odds are good.) Ship hydrodynamics has advanced very little over the last 40 years so amateurs shouldn't despair at not understanding the wave-making problem. In its final report to the 24th ITTC in 2005, the Resistance Committee, concluded that it could not propose general guidelines for the prediction of far-field waves and wash effects because there was not enough experience with the problem. Numerical methods, it seems, are still evolving, and experimental data required for validation of predictions is almost non-existant. So, after millions of dollars and many thousands of man-hours spent on the problem, we are still a long way from even a reasonable understanding of the physics involved. CFD is, of course, an enormous advance because we can now display our almost complete ignorance in full colour! \bibitem{Doi80} Doi, Yasuaki, ``Observation of stern wave generation", Proc. Continued Workshop on Ship-Wave Resistance Computations, Izu Shuzenji, Japan, 10-12 Oct. 1980, pp.\ 155--172. \bibitem{Kajitani87} Kajitani, H., ``A wandering in some resistance components and flow", {\em Schiffstechnik\/}, Vol. 34, 1987, pp.\ 105--131. \bibitem{Maruo76} Maruo, H., ``Ship waves and wave resistance in a viscous fluid", Int. Seminar on Wave Resistance, Japan, 1976, pp.\ 217--238. All the best, Leo. |
| Wow! I suppose that would be why my local barnes ignoble doesn't have a book on it's shelves titled "Wave Making for Dummies"! Many thanks all for illumination. I have reread all replies twice now and if I do so a few more times I think I might begin to understand the depth of my ignorance! Really though, a tough topic to explain to an art history major and well done. Paul |
Leo. |
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| Which Hull Shape? | monrosm@shrewsb | Boat Design | 8 | 08-10-2006 11:54 AM |
| speed & Trim angle curve by maxsurf, hull speed | Joe Lu | Software | 1 | 11-25-2004 07:37 PM |
| need guidance on hull shape | gerard baladi | Powerboats | 2 | 11-19-2004 08:56 AM |
| Hull Shape | mrbrown | Boat Design | 1 | 08-09-2004 12:24 PM |
| Hull shape problems | Les | Powerboats | 5 | 03-24-2004 10:34 PM |
