Old 10-07-2005, 06:36 AM
Danielsan's Avatar
Danielsan Danielsan is offline
Amateur designer-builder?
Rep: 10 Posts: 229
hull lines
Any one knows a way to export solid hull to hull lines?
any available software?
greetz,
Daniel Peeters
Old 10-07-2005, 12:17 PM
CGN CGN is offline
Rep: 121 Posts: 547
Can you explain a little bit more Danielsan i'm not sure what you need
Old 10-07-2005, 12:34 PM
Danielsan's Avatar
Rep: 10 Posts: 229
1 or 2 images say more than a 1000 words
this will simplify the quetion, have a look at the images.
A) I have designed a hull upon surfaces and cutouts,... (See rend_1.jpg)
B) I would like to get the lines drawings of my hull. (See loft-1.gif)
thx in advance,
Daniel Peeters
Old 10-07-2005, 03:34 PM
mattias mattias is offline
Rep: 10 Posts: 8
I don't know what computer software you use, but try to draw lines at whatever distance you like and then project them onto the hull.
Old 10-07-2005, 08:43 PM
Bruno Mattoso Bruno Mattoso is offline
Rep: 10 Posts: 3
Dear Daniel,
you can try getting the main dimension like LOA, B, T, D, and put it on a milimetric paper with 3 views: LOA x D, B x D and LOA x B. Drawing the main dimensions on the paper, and use your skills to give shape for your boat.
Keep in mind that, if you change a point in one of the views, all the others must be change.
Old 10-07-2005, 09:07 PM
WilliamS WilliamS is offline
Naval Arch.
Rep: 10 Posts: 6
3d HULL
Try using planar surfaces in XY, XZ, ZY planes, and intesecting these planes with the hull surfaces, normally X is the lenght, Y beam and Z depth, so a XY plane with a Z=0 is the waterplane 0, using others Z values can you make others waterplanes, same for XZ for profile and ZY for sections..............
What software are you using?
Willi
Old 10-07-2005, 10:34 PM
CGN CGN is offline
Rep: 121 Posts: 547
Danielsan if you are using solidworks you are going to need to create planes to cut sections trough the hull to any given distance create sketches from this sections, then once you have the sketches move them all to 0, and then export to dxf all the sketches should be in one plane at 0. it may not work as I said but that's the idea how should work, is a PITA from solidworks, but if that is not what you are looking for have a look at this paper.
Old 10-08-2005, 05:20 AM
Danielsan's Avatar
Rep: 10 Posts: 229
Yep, indeed
As a matter of fact I use Solidworks, and indeed if i want to get some lines i need to cut the boat in pieces(slices) by using section lines , this works.
actually from time to time I have access to maxsurf, and if you put in some shape into that program, it can give you the body plan in no time. It would like to export the surfaces of my SW to maxsurf but there are to many, ast it takes into account al the filetsa nd other small faces, so this don,t work and this leaves me with using the section lines in SW drawings.
Thx verry much for the info,
Daniel Peeters
Old 10-08-2005, 06:16 AM
Naval Arch.
Rep: 10 Posts: 6
For you next design try using www.rhino3d.com
Willi
Old 10-08-2005, 05:20 PM
Danielsan's Avatar
Rep: 10 Posts: 229
yes, this would mean to get along with yet another type of software, all this needs time, I am only an amateur "designer" and I don't have all the time + the money to get all the software...
greetings,
Daniel Peeters
Old 10-13-2005, 05:16 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I am sure solidWorks has some kind of macro language like Visual Basic, VBA or simmilar. You can probably make (or record?) a macro that sections "everything" at certain intervals. I do that in AutoCAD, IntelliCAD and Rhino.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
