Hull lines for a 36' Higgins L.C.V.P.
Discussion in 'Boat Design' started by Proflooney, Nov 20, 2016.
  1. Proflooney
    Proflooney Junior Member
    Ok so now I am ready to get started on this thing as a CGI Ship Build then a 1/6th scale radio control model.
    here is my first Hurdle. the TOO for this is in a different layout than I am used to. the stations are on top and I dont see waterlines listed but rather heights above base for things so I am not sure how to set this up in excel for my curve table to import
    if anyone is interested the few factory drawings I have found are here: http://www.proflooney.net/LCVP.rar
    I am wondering if someone can point me into the proper direction to set up my excel file as I am used to seeing waterlines on top row stations on the side. also for the B1 and B2 and chine lines how do i set them up in a table so it will draw them offset properly from centerline
    thanks
    Joe
  2. TANSL
    Likes: 706, Points: 123, Legacy Rep: 300
    TANSL Senior Member
    You have the full fairing of the LCVP and the submarine. Why do you need their TOO? I would advise you not to draw each and every one of the frames but, for example, one out of five, just to get a digital faired body lines plan, from which you can obtain the cross sections you need to make your model.
  3. Proflooney
    I dont know anything abt the full fairing or whatever you talking about think of me as a kindergardner in ship design. I prefer the TOO because it would be more accurate plus I am wanting to learn the use of tables in my software program more.
    I have tried using the outlines on the view that shows the bulkheads but they run together and are confusing to me where the TOO is easier for me to understand and draw with.
    On the LCVP the TOO are different than I am used to and with the ones that are offset from the centerline I need to figure out how to write the table for them.
  4. TANSL
    TANSL Senior Member
    Since you seem to be an expert in SolidWorks, you could use the .tif files you have, inserting them as raster image references in a SolidWorks drawing, scale them to the scale you need, and get as many half breadths you like.
  5. Proflooney
    Ive done that But I want to do it Via the TOO since I have them I want to use them to set up all the tables for solidworks. its not so much that I cannot spend the time tracing them as I want to get used to creating and using the tables in solidworks
    Added my fletcher excel sheet to give you an idea.
    the reason why I want to get used to doing it with the TOO is because I want to eventually take the data for an iowa class battleship and that will be more than just tracing a few lines as I want to do the entire ship in cad all decks, hull, subframes etc.
    so I am practicing and learning now on smaller projects
  6. TANSL
    TANSL Senior Member
    Well, I'm not able to understand what you need to do. I guess, but I'm sure I'm wrong, you need the TOO to draw the cross sections and, with those curves, cut the section in wood or any other material.
    That's why I tell you to forget the TOO and draw the frames directly.
    I think I'm not able to help you, so I will not make you waste any more time with me. Good luck in your project.
    Cheers.
  7. Proflooney
    Well i am not basically worried about cutting in wood I want to draw the entire boat in 3D cad Just as though it was coming out of the shipyard. Virtual Modelling they call it.
  8. TANSL
    TANSL Senior Member
    Then, my friend, you don't need a TOO at all. Things are much easier.
  9. Proflooney
    I know I dont NEED it but I am wanting to use it it is my preference to use it
    when I get to something like an Iowa Class Battleship I will need to be able to use them for all the various lines I will need so this is practice
  10. TANSL
    TANSL Senior Member
  11. Proflooney
    Ok I got it all figured out tonight. needed to step away from computer for a bit.
    I have to use the stations like normal in the curve table, then the height above baseline as my waterlines, and for the keel, B-1, B-2 I use those as my width in the table which would be the offset from the centerline.
    so that table of curves would be the same as a buttocks curve setup.
    then I use the same info but in the third column I use the sheer and chine Half Breadths as my widths to generate the curve table for the sheer and chine.
    i guess sometimes it takes getting away from the project for a few mins to make everything clear
  12. Proflooney
    PS Tansl you didnt waste my time just allowed me to have a little distraction chat that i needed so actually you had helped me in your own way :)
