Old 02-12-2008, 08:24 PM
oops! oops! is offline
Rep: 16 Posts: 18
is hull design different between i/o and a thru hull
hi......im basically new here so i hope im in the right forum......
im currently restoring my 1969 searay srv190 i/o
i have extended the hull from 19 to 24 feet.......
i was thinking of going to a mid engine design with a thru hull prop shaft .....
i was wondering....is there any difference in hull design between a standard i/o and a mid engine?.....obviously the stringer/motor mount is different.
the boat is gutted and im just about to do the stringers so......if im gonna go mid.....now is the time
any input would be apperciated
cheers
oops
Old 02-13-2008, 01:16 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
oops,
You have added a bunch of buoyancy aft by lengthening the hull. If your engine, tanks, etc. remain in the original location, the boat will float bow down. Thus you need to move major weights (engine & tanks) aft. How much aft is the question......
Tad
Hull finish on high speed hull. Polished or Matt? Sooty Boat Design 2 02-03-2008 12:08 PM
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 12-31-2005 11:40 PM
what is faster a flat boat hull or a vee pad hull riveramunizaga Boat Design 24 05-24-2005 02:18 PM
hull boat redesigns (hull pad project) riveramunizaga Boat Design 9 05-12-2005 08:35 PM
Hull or hull & deck broke apart during 40-50 mph turn Jeff Powerboats 1 07-09-2002 12:27 AM
