Old 07-14-2010, 03:42 PM
Nakis Nakis is offline
Rep: 10 Posts: 2
hull design
i wonder if a hull will be as a W , (instead of a V ), with 2 large Vs and in their join , to have many small hoses to offer press air under the hull with an angle to the back of the boat.
Do you think that the millions of air bubbles will reduce the abrasion of the boat on the water??
In the joint of the 2 Vs , will be created a corridor from the front up to the back side of the boat full of air.
I just wonder....
Old 07-14-2010, 04:40 PM
Rep: 1758 Posts: 1,561
Old concept. Look up "M" hull or "catheral hull" for high speed boats. Or any power cat or multi-stepped planing boat of the 1920's or 30's for that matter
Old 07-14-2010, 04:59 PM
Mild Bill Mild Bill is offline
Well, not entirely mild.
Rep: 11 Posts: 32
For starters:
Hickman Sea Sled - Inverted Vee
Here's The true Sea Sled Story, circa1985
barn found hickman sea sled
Cathedral Hulls??
I read somewhere once (maybe in one of the above links, or one of the links they contain) that Hickman Sea Sleds and other inverted-V designs were supposed to be fast because they were riding on foam/bubbles created by the wake interacting with the airflow, which foam/bubbles were supposed to have less drag than "solid" water. Though fast, the early Hickman Sea Sleds with vertical sides (i.e. like an upside-down 'M') were reportedly susceptible to tripping while turning sharply at high speeds, the cure for which was to add a bevel to the outside edges, which would resemble your proposal for a 'W' hull.
As for venting compressed air underneath the hull to increase the quantity of bubbles and maybe add a bit of lift, it might decrease the drag but you have to be aware that it would add considerable cost, increase complexity, add weight, and divert power from the propeller. Those last two will act to slow down the boat, so you may end up with an insignificant improvement in speed in exchange for spending much money.
Delftship Design Question on Design Drag vs Hull Ratio Fanie Boat Design 10 06-08-2009 06:43 AM
is hull design different between i/o and a thru hull oops! Boat Design 1 02-13-2008 01:16 PM
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 12-31-2005 11:40 PM
hull design / furniture design bogeyinthekeys Software 10 09-18-2005 07:16 AM
Hull Design Magsls1 Fiberglass and Composite Boat Building 1 08-19-2004 08:21 AM
