Old 05-11-2011, 09:43 PM
cjgadget cjgadget is offline
Hull for Amphibius Aircraft - New Comer
I am new to the group, and very poorly versed in hull design, or with anything pertaining to boats for that matter...
I am a commercial pilot with a degree in aerospace engineering, with experience in control systems design(mostly electrical stuff). I am also building a composite aircraft called a Cozy Mk IV.
I am doing some brainstorming on an aircraft design, similar to a Nardi Riviera. I have some idea of what the airframe design needs to look like and the construction methods used if I were to design with composites, but I am completely clueless about the hull. What types of constructions can be used? What is the work flow in determining the shape of the hull w/ regard to acceleration and speed requirements(takeoff distance). How due I assure the center of pressure and center of gravity locations provide for a stable hull? Are there simplifications I can make in the analysis.. i.e., can I just design a "boat" with similar weight/capacity to get a rough idea of things?
I know this is an extremely broad inquiry. I do expect this endeavor to take up a good portion of my life(20-30 years). But, I am interested in starting learning - if not only to determine it'll always be outside my capability.. Any help or references would be very much appreciated!
Thanks.
-John
Old 05-12-2011, 11:16 AM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 707
how about skiis like the SeaDart?
Note there was also a single ski(deep-V) version of this.
I'd imagine the biggest fear of the seaplane pilot is finding you have nowhere to land due to sea-state.
Skiis on mechanical shock absorbers should greatly increase the landable range of sea-state, and maybe the takeoff-able sea-state. Maybe incorporate land wheels into it.
No idea about the 'work flow' in the calculations, but I've heard seaplanes reach takeoff speed but must be then 'snapped' off the water to break some suction.
Another interesting amphib concept used a hovercraft style bag.
Not this one....
http://www.hovercraft.com/content/in...=index&cPath=2
It was a fully flying aircraft built in the late 1960s
Old 05-12-2011, 11:28 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Republic Sea Bee
Probably one of the most famous small flying boats of all time, the Republic Sea Bee
http://en.wikipedia.org/wiki/Republic_RC-3_Seabee
There is a perpetual story that "once upon a time" a Sea Bee forgot to put her gear down for a airstrip landing and landed on her hull. They jacked her up, dropped the gear and she taxied away none the worse.
There is a pile of data on this aircraft, if you're not familiar with her she's a good place to start.
Steve
Old 05-12-2011, 11:33 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
Excellent reference work: "The Design of the Airplane" by Darryl Stinton-all your questions are answered there as best I remember....
Very cool new ultralight seaplane: http://www.flynano.com/
click on image:
yes, it is a revolution
Old 05-12-2011, 11:36 AM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Welcome aboard, cjgadget
Basically you need a planing hull with enough volume to support the weight of the aircraft. Most modern seaplanes also incorporate a stepped hull to assist in getting out of the water.
You might also talk to Jeremy Harris on this forum. I know he builds aircraft as well, though I don't know if those include seaplanes.
Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR
Old 05-12-2011, 12:14 PM
Rep: 193 Posts: 707
I see a slight prob w/Flynano's Prop-Ahead-of-Pilot's-Face arrangement.
The prop blast would be around 100+mph of 'dirty air'.
I've been on motorcycles with just goggles at 90mph and with full face helmet but no windscreen at 115mph and the wind-blast is distracting to say the least...and that is smooth "clean" air.
I'd imagine you would have very nasty buffeting pulses from the prop at whatever the prop's rpms are, as well as major prop noise problem that wouldn't be solved with ear plugs.
At least the Flynano has a very short range/duration.
Old 05-12-2011, 12:23 PM
cthippo's Avatar
Rep: 452 Posts: 725
Old 05-15-2011, 08:13 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
click on image:
Couldn't see any actual real flying macnines, and there was no reference to them in the Aero 2011 that they said to look them up in.
This has all the earmarks of 'vapour product'
Old 05-15-2011, 08:26 AM
Doug Lord's Avatar
Flight Ready
Fly Nano OY is listed at Hall/Stand number B4-306
http://osc.messe-friedrichshafen.de/...rt=&spposland=
Old 05-15-2011, 08:51 AM
viking north viking north is offline
Rep: 727 Posts: 1,161
CTHIPPO, CT, I have a spare cylinder (jug) from the engine in your french fighter if it is using the Gnome engine. photo below.
KEYSDISEASE-friend of mine owned one of those in Stephenville NFLD. Like the bumblebee it's hard to imagine they could fly. It was painted a medium brown. He purchased it from somewhere Stateside, actually flown in and landed in Stephenville. I've been around aircraft all my life but this was the weirdest thing i've ever seen.
CJGADGET- You're into some complicated engineering, boats married to aircraft, liquid, air, and fire to make it move--good luck
Hull for Amphibius Aircraft - New Comer-img-2-.jpg  Hull for Amphibius Aircraft - New Comer-100_0834-2-.jpg
Old 05-15-2011, 09:00 AM
rwatson's Avatar
Ah yes, they have reserved a booth - but it IS 'vapour product' - they are still at the static towing, non flying protoype stage
http://www.youtube.com/watch?v=GyKrZoAF1x8
I hate it when people promise the 'free and easy miracle product' and it hasnt even worked yet.
Old 05-15-2011, 09:11 AM
Wow--don't know if i'd be comfortable with a spinning prop right there in front of my face. I can just visualize a seagull strike. I bet you see this modified as a pusher in the Mark II version--
Old 05-15-2011, 10:23 AM
claydog claydog is offline
Rep: 37 Posts: 41
This amphibian that's just starting production might be worth a look by the OP. Very cool IMO.http://www.iconaircraft.com/
Old 05-15-2011, 11:10 AM
Doug Lord's Avatar
Flight Ready
They've got a prototype, they've done model testing-hardly a "vapour product"! I wish them luck-they're doing what every other plane manufacturer does. They're in the testing stage with a real airplane for crying out loud....
Old 05-15-2011, 11:13 AM
Doug Lord's Avatar
Flight Ready
I like it-they say "hydroplaning tests complete". Seems they've sold 500 ahead... pretty good if it works as well as it looks.
submersible aircraft rasorinc Boat Design 17 07-23-2009 08:25 PM
aircraft carrier's stability phxysius Stability 16 04-29-2009 07:41 AM
Submersible Aircraft juiceclark Boat Design 21 11-04-2008 10:11 AM
Modern Aircraft Carrier Dook Boat Design 105 10-20-2007 07:14 AM
Fantasy Aircraft kach22i Open Discussion: All Things Boats & Boating 11 02-10-2006 01:42 PM
