Old 04-04-2017, 03:30 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 304 Posts: 1,185
how to they get wooden wings to bend on this slide-seat rig?
http://www.boatdesigns.com/Sliding-R.../products/188/
Looks like something that requires you to fab your own high quality plywood, which could entail high quality forms, presses, epoxy, steam, lots of time and effort.
Wouldn't make more sense to bend some 1/4" 6061 and weld in a brace if needed? Any shop would do that in 10 mins for a 12 pack.
Old 04-04-2017, 03:56 PM
upchurchmr upchurchmr is offline
Rep: 579 Posts: 2,396
I don't remember but the same plans are available on other sites for nothing.
This is really old from Popular Science or Popular Mechanics.
There is even a SOF kayak designer who tried to pass it off as his work.
Old 04-04-2017, 04:20 PM
NoEyeDeer NoEyeDeer is offline
Rep: 300 Posts: 977
Not really. Those outriggers should be pretty easy to laminate. Can't see it being an issue for anyone who has done a bit of laminating before.
Old 04-04-2017, 04:47 PM
seems like it would a pretty big chuck of lumber to make a form big enough to do something like this.
https://www.youtube.com/watch?v=g7FuNHshRnw
Take a bandsaw to a 3'x1'X6" header block?
Old 04-04-2017, 05:24 PM
Yacht Designer/Builder
Rep: 3967 Posts: 17,963
I Agree, the wings look fairly simple to jig up. A simple form screwed to a table, some clamps and veneers. Steaming wouldn't be necessary, though a heat gun could help speed things up, if the veneers are fairly thick.
Old 04-04-2017, 06:03 PM
Rep: 300 Posts: 977
Not really. Just some 4x2 offcut blocks screwed to an MDF base board. Should be adequate.
Although personally I'd probably steam the laminates first anyway. I generally prefer doing it that way. It's easy to do. They dry off fast in decent weather, and are easier to deal with when gluing up.
Old 04-04-2017, 10:17 PM
tmark tmark is offline
Rep: 60 Posts: 78
We used to make longboards (as in the skateboard type), the shapes of which were far more complex than that ... we would make the forms out of rigid pink insulation and stick in a vacuum bag. If it wasn't a complex curve we'd even do away with the bag ... 1/16 maple veneers, birch veneers and 1/8 3ply baltic birch ply were the go to materials.
If I were making those wings I'd be tempted to start off by strapping 3 sheets of baltic birch ply around a metal barrel and glue with Titebond 3.
ASHES | STILL WATER BOATS . COM
Canoes. Paddles. Plans.
Building Plans for Strip Construction
Old 04-05-2017, 06:33 AM
fredrosse's Avatar
fredrosse fredrosse is offline
USACE Steam
Rep: 56 Posts: 292
Cheaper/Easier???
I would like to know where this "any shop" is that will do this in 10 minutes for a 12 pack.
Old 04-06-2017, 08:22 PM
rower mike rower mike is offline
Rep: 13 Posts: 13
the sides of the slide seat system where the riggers mount have to withstand all the force... so have to be beefy... and the riggers have to clear the gunnel anyway...
so the other designs out there that just mount onto the gunnels and bridge from gunnel to gunnel.. like this one
http://www.gaboats.com/tutorials/outriggers.html
make a lot more sense, if you are ok with mounting things that way... probably save weight and work...
Used a 5/4 ie 1.25inch cedar deck board myself, two half lap joints expoxied to make my "wing" style rigger as above ...but "U" shaped vesu "V"
lot of hrs on it and it is still going strong.
Old 04-06-2017, 08:32 PM
Mike,
I didn't see your picture. Please.
This type of a installation is so you can easily remove the rowing rig.
2 to 4 screws or wing nuts and it's out.
Minimal cutting up of your boat.
Similar in concept to a Piendosi unit.
Old 04-07-2017, 02:26 AM
Old 04-09-2017, 06:08 PM
Rep: 13 Posts: 13
my set up
Old 04-09-2017, 09:38 PM
Thanks Mike.
Looks good for a fixed installation.
I assume it wouldn't take too long to remove if you ever desired - Just to use the boat as a canoe, of course.
Rig, rudder and centreboard design for a wooden dinghy hmacread Sailboats 3 12-30-2016
06:15 AM
sliding RIG, fixed seat, rowing setup Squidly-Diddly Boat Design 3 03-10-2014
07:50 PM
anything 'terribly wrong' w/slapping sliding seat rig into 14' Oday sailboat? Squidly-Diddly Boat Design 9 08-05-2013
11:17 PM
Plans for a "universal" sliding seat rower rig? Squidly-Diddly Boat Design 1 11-06-2007
10:05 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
