| How is this sportfisher hull? Hey everybody, I did this on the free version of DelftShip and would like some guidance. Please be as brutal as you feel is necessary. I'm sorry but I don't know how to make a thumbnail view of DelftShip. Thanks for the views, Michael |
| In Windows, open the image in delftship, press the "printscreen" or 'prtscrn" on your keyboard (usually upper right area) You now have the screen captured as an image in the Windows clipboard. Open microsoft Paint or other imaging software and edit, paste the image. Save as .jpg. Long way around (sigh) |
| Hey Timothy, Thanks for the reply. I knew how to do that but I thought you could do it in DELFTShip. There is an option to save a preview picture and I thought that I wasn't doing it right. Other than that, what do you think of the boat? If you enable control curves, you can see a lot more detail than with the control net. Be brutal. |
| Be awful hard to plank in mahogany, if you wanted any width to the planks. Lots of twist forward. You might want to think about just a smidgin of convexity in the forefoot area, you can gain a lot of strength that way. Like 3-5 mm worth of dome on each station frame.
__________________ You make Baby Jesus want to drink Scotch out of the cat bowl |
| Thanks for the replies! Hey guys, I was thinking of cold molding it from narrow strips of 1/4" marine ply or something like that. Adding some width to the forward frames sounds easy enough to do if it will make a stronger hull. You might be able to tell that I was going for kind of a Carolina sportfisher look. What about the DWL? Is it about right for the weight of the boat when it's finished? I don't want to build it just to have it sit 3' low when all is said and done. Thanks again, Skovian |
| Ah, now you come to the tedious part-you have to specify the weight and distance both longitudinal and lateral from some arbitrary point near the center of the boat of everything in it including the hull. adding all this up and calculating the moments from the center will give you a total weight and center of gravity. Now all you have to do is move the load waterline around until the underwater shape displaces that much weight and the center of buoyancy matches the c.g. Several old timey books tell how to do this manually, but I couldn't begin to tell you how to do it in DelftShip. Just looking at what you have, it looks a little shallow for a Carolina boat, not enough displacement, and maybe a little more deadrise forward. |
| Sportfisher Project | ALAN GERMER | Boat Design | 1 | 06-07-2007 10:57 PM |
| SportFisher Design | Troutcatcher | Boat Design | 1 | 06-04-2007 03:45 PM |
| Sportfisher Running Strakes | altim | Boat Design | 0 | 07-21-2005 02:48 AM |
| Single Diesel Sportfisher? | Corpus Skipper | Powerboats | 12 | 05-26-2004 06:20 PM |
| sportfisher or motoryacht | sonny | Powerboats | 1 | 03-15-2004 08:34 AM |
