| How to setup 12 ft tunnel hull I have a scat cat type of 12 ft 2 seat tunnel hull and a 15 hp mercury long shaft 4 stroke motor when I try to run it fast it just plows and tries to drop on a plane but as it does the motor seems to cavitate and shake and I feels like it is about to damage the transom. Is a tunnel set up differently then a regulat boat hull? what must I do? ![]() |
| Most outboards with tunnels will shake and ventilate some. as far as the plowing, sounds like you have too much weight foreward. a 12 footer is pretty sensitive to weight distribution. Is your battery under the console? Try moving it aft, as well as the fuel tank. Finally, a poorly designed tunnel will cause a suction, but this usually pulls the stern down.
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| If it's an outboard, you can change the angle (motor - surface of the water) too see here http://www.boaterexam.com/ |
| The motor angle is set like the one pictured at the bottom but the boat plows along like the one in the middle. Am I running with too little hp (15)? |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 02:20 AM |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 10:51 AM | |
