Old 02-26-2010, 08:58 AM
jbheels jbheels is offline
Rep: 10 Posts: 4
How to put a tunnel in a flat bottom skiff
I have an 18' flat bottom skiff that is 72" wide at the bottom. I am going to be in some seriously shallow water so I was thinking of putting a tunnel in the bottom and buying a jack plate. Any thoughts on how to construct a tunnel for inexpensive? Thanks
Old 02-26-2010, 10:36 AM
mark775
No but do tell of what and how it is constructed. Actually, post pictures.
Old 02-26-2010, 01:00 PM
dand0_4 dand0_4 is offline
Rep: 10 Posts: 21
Down here at South Padre Island, Tx. we have to operate in the shallowest bay system in the US. Average depth is less than 2 ft.,a lot of it less than 1 ft. Tunnelboats are the norm here, but they are difficult to design correctly. Before you butcher your boat and possibly ruin its performance here are some suggestions that I use to run my nontunnel boat in water as shallow as 4 inches. First, and most important, a good stainless 4 blade supercupped prop. Extreme cupping is essential. Second a jackplate with 6 in. setback, and last but definitely not least is a Bobs Machine transom water pickup. The water pickup can be modified with a stainless livewell screen to keep grass out, very important. With this setup I can run in 4 inches and take off in 12 or less if the bottom is soft and the transom pickup keeps mud and grass out that other low water pickups ingest.
Help building a 17' long x 50" bottom flat bottom aluminum boat Loewman Boat Design 22 11-21-2011 12:31 PM
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
Comparison testing of an Atkin tunnel-stern v-bottom Seabright skiff and another boat kengrome Boat Design 79 06-25-2008 05:35 AM
Flat Bottom Jet Tunnel dick stave Boat Design 4 04-14-2006 01:56 PM
Tunnel Design help for Flats Skiff DanAyo Boat Design 13 10-29-2003 03:04 AM
