| How much speed would be lost using WW2 E-Boat hull as the basis for a fast motor cruiser/motor-sailor when in sail mode?...... when compared to a 'from scratch' designed motor sailor or pure cruising sailor of same size. Figure the E-Boat based hull would feature drop keels for sailing. |
| I depends on what you design. Unless you give us a design to compare it to, there is no answer.
__________________ Gonzo |
| E-boat is really S-Boot and highly specialized for what it was. No way to make it something else and still have it be same. Easy to make sailboat same beam/length ratio but S-Boot designed to go 45 knots on 4,000 hp with big war load, not a sailboat at all. |
| Dragon boat hull speed: "W" hull vs. flat hull | JosephT | Boat Design | 26 | 09-11-2010 02:44 PM |
| Lost power in heavy seas - which hull shape? | kach22i | Stability | 20 | 02-28-2008 12:58 PM |
| Fibreglass repair on a speed boat hull. | bigsk74 | Powerboats | 2 | 08-30-2006 09:48 AM |
| speed & Trim angle curve by maxsurf, hull speed | Joe Lu | Software | 1 | 11-25-2004 06:37 PM |
| best hull design for high speed boat | almesbah | Open Discussion: All Things Boats & Boating | 8 | 07-15-2004 01:46 PM |
