Old 10-30-2006, 10:36 PM
Rep: 505 Posts: 1,658
how much power?
hey guys ,,I got 32ft length ,,25 l.o.w,,boat weight is 10,500lb 3.300 lead ballest ,,am considering placing 1 or 2 small 4stroke outboards in the well..?how much horsepower do you think I need ?
Old 10-30-2006, 10:40 PM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
To do what?
15-20 HP will push her to S/L 1.2 or better.
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 10-30-2006, 11:07 PM
to get out of the slip ,,maybe some river cruising ,,would like to get 4 or 5 knots for cruising,, was thinking 2 for enough control.
Old 10-30-2006, 11:34 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Ahh.... I was thinking you wanted to show up some of those Hallett rocketships down on Havasu
Single 20 would be typical of boats that size around here, who use it for similar purposes as you suggest... if your heart is set on twins, I guess a pair of 9.9s would do, I figure you'd want the widest prop and biggest gear reduction you can find for a heavy boat like that.
Old 10-30-2006, 11:50 PM
marshmat,,that raises another question,,iv been told that she is light for her size,,and I know with 2 engines ill have more drag,,,but I got almost 500 sqaure ft of sail ,,and Im a novice,,not intending to set any records ,,just some sailing and fishing .besides at 55 knots I start screaming for my momma
Old 10-31-2006, 12:00 AM
marshmat's Avatar
Perhaps for her size she's light... but the question is, what'll a 300 cc outboard think of her? You're certainly familiar with how high-strung kicker motors can be... what they really like is flying along on a little fishing skiff, so if you can find a really steep reduction and swing a really wide prop, that'll make the little brutes a lot happier on what they will see as a big slow boat.
Old 10-31-2006, 01:29 AM
RHough's Avatar
Retro Dude
A 32 foot sailboat with no engine? That's pretty rare.
For years, the Universal Atomic 4 was the power for boats in that size range. Although rated at 30HP, most installations do not allow the engine to run fast enough to get full HP. 12-18HP Diesels were common repower options.
I'll assume that the boat has some sort of fixed keel, you won't gain much in manoeuvrability with two engines. One of the high thrust OBs from Honda or Yamaha would do ok. 15-20 HP.
If the boat had inboard power and you are thinking about putting an OB on it instead of replacing the inboard ... my your soul rest in piece ... I've never seen a sailboat designed for inboard power "improved" by the substitution of an OB. The boat will be cursed.
- Thomas A. Edison
Old 10-31-2006, 05:10 AM
Rep: 700 Posts: 3,208
3hp per ton does just fine , 5 hp per ton is as much as most sailboats can ever use.
IF much engine time is contemplated a "high thrust " option and an engine with a somewhat larger alternator would be 1st choice.
FAST FRED
Old 10-31-2006, 11:14 PM
thanks for your input guys ,,,longliner,,still dont know what Ill do,,as of yet
New Power scarab21 Gas Engines 0 07-10-2006 03:19 PM
I Need Power Steering Help!!!!! stoliti Propulsion 1 04-02-2006 12:28 PM
Sail power and horse power? kjell Motorsailers 12 09-03-2005 04:20 AM
SAIL to POWER tschienque Propulsion 4 12-23-2004 12:45 PM
Power Mike D Option One 11 06-01-2003 09:12 AM
