| Chris, I guess I should have said, "A weight study might take 120 man hours, but it's not required to create a boat that floats.....sort of." ![]()
| came acros a relation between weight study and construction cost i want to share, some funky boats too ( cats probably more expensive ) Quote:
| I am in the process of designing a 49 ft sailing cat, and am using a NA to finalise the design, and do all the detailed engineering. I initially asked around regarding prices, but only NA's who had proven sailing cat design experience. The prices I was originally quoted are in the region of the 50-100k. But once we got down to defining exactly what was required, they crept up closer to the 100k mark OK, if I could use an earlier design that the NA could reuse to a large extent then we came down to 40-50k. The estimates were based on a very detailed weight study that needed to be done, and I would never even consider a catamaran design without one. Our weight study has more than 1000 data entries at the present time. Just defining the equipment, deciding on the supplier, getting the weights is a time consuming job. Building costs: You can get a 50 footer built from stock plans in foam/polyester from around 400-500K if you go to a low cost labour country. If you want some good kit on board, and a reasonable internal finish the hours pile on. The hulls, deck and bridgedeck and bulkheads weigh around 2,3 tons using infusion and foam/epoxy. I expect around 10000 - 12000 hours for my boat with most of the insides painted. For the designs pictured, I would estimate build costs to be >700K for a one-off boat. So if there are any NA's here who will design a 50 ft sailing cat to ABS or ISO, and do it for 30 K, let me know, as I have another project in mind. Anyone who will build one for 250K including 2 engines, good rig, then get in touch please. Regards Alan |
| Roger Hill or Chris Tucker are very capable, with lots of experience. $100K is 2x what this should cost of you go with a proven hull design and a custom layout for yor needs. |
| building a custom boat | elcapitan | Fiberglass and Composite Boat Building | 11 | 10-17-2006 05:22 PM |
| custom jon boat | chodedawg | Metal Boat Building | 5 | 08-24-2006 06:38 AM |
| need help building custom boat | mini_man91 | Boat Design | 2 | 05-30-2005 05:59 AM |
| Window Design for Custom Steel Yacht | pkoken | Boat Design | 17 | 05-05-2004 07:53 PM |
