how to make a wooden trailer sink ? ? ?
Discussion in 'Boat Design' started by philipa9, Jan 10, 2014.
  1. ancient kayaker
    Likes: 147, Points: 0, Legacy Rep: 2291
    ancient kayaker aka Terry Haines
    Not even boat-builders use 1/12ths . . .
  2. messabout
    Likes: 511, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    AK the term Minch and the term Mensch..... minsch (sp) are vastly different. A mensch in yiddish vernacular is a person of considerable kindness and merit. I am not jewish but that is one that some of my aquaintences use. Minch is a whole 'nother deal and yes it is in the urban dictionary. I have never heard, that I recall, the word minch. Now I have, and I have explored its meaning. I did not really need to add that word to my vocabulary. Amazing, the things we learn on this forum. :D
  3. keysdisease
    Likes: 43, Points: 28, Legacy Rep: 324
    keysdisease Senior Member
    make the trailer out of lignum vitae or ironwood, simple:p:p
  4. SamSam
    Likes: 200, Points: 63, Legacy Rep: 971
    SamSam Senior Member
    For me, if I want to make something that sinks, all I have to do is build it to float.
  5. nimblemotors
    Likes: 3, Points: 0, Legacy Rep: 4
    nimblemotors Senior Member
    If you leave the trailer in the water for a while, it will stink eventually, so it just takes time.
    oh wait, I got that wrong. If you want to make a trailer sink, I would make one from fiberglass or concrete, one from wood isn't so durable,
    those are usually called troughs.
    But if you want the wooden trailer to sink and not make one, putting wheels on the boat is a great idea,
    or better yet, make your bike into a boat and forget the trailer.
  6. Easy Rider
    Likes: 46, Points: 0, Legacy Rep: 732
    Easy Rider Senior Member
    I launch kayaks and canoes from the bed of our 14' utility box trailer.
    So I'm with the other poster to install a plywood platform and launch boats w the aft end of the platform at water level.
  7. nimblemotors
    Ran across this, thought it would be helpful:
  8. kapnD
    Likes: 414, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    Back to the OP's original question, filling the tires with liquid should help tremendously, it is commonly done with slow moving heavy equipment, though usually only the bottom third is filled as an aid to stability. Fully fluid filled, the tires will no longer be buoyant, which is probably most of the current problem.
    1 person likes this.
  9. alan white
    Likes: 123, Points: 0, Legacy Rep: 1404
    alan white Senior Member
    They would fit into brackets, lift out, dip in water, set back in brackets. Drain at leasure. Rocks or sand would be a lot more work because they drain poorly.
